Old 03-29-2021, 11:20 AM   #1
CA Victoria
CA Victoria's Avatar
Default Magna flux tool
I am on a search For this tool. It’s a magnet used to magna flux with. It doesn’t have a name on it, hoping someone can help with the manufactures name?
Thank you
File Type: jpg 41FFF977-B7F1-4CB7-9333-4A9C8749C6D4.jpg (38.4 KB, 41 views)
File Type: jpg 8C6E2809-8395-4A7A-BA71-5E648F088667.jpg (67.1 KB, 42 views)
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 03-29-2021, 01:30 PM   #2
51woodie
51woodie's Avatar
Default Re: Magna flux tool
Probably a very old unit, that uses permanent magnets instead of electricity to generate the needed magnetic field. Would likely work if you had the appropriate ferrous powder to "dust" the area being tested. The link below is for a supplier of mag particle test equipment.
https://www.ndtsupplies.com/y2.html
51woodie is offline   Reply With Quote
Old 03-29-2021, 01:39 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
I don't have a clue as to the origins of the tester in your picture. But if you would like to build your own tester its simple to do. The machine shop I frequent has a home made tester it was built using the magnets form a pair of old speakers. No electricity needed it works extremely well.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 03-29-2021, 02:03 PM   #4
hotrodart
hotrodart's Avatar
I am quite sure a good/strong horse shoe shaped magnet will work with iron powder......should show all surface cracks.
hotrodart is offline   Reply With Quote
Old 03-29-2021, 02:55 PM   #5
Baggs
I think you are correct. My shop let me use their “portable” unit several years ago while I was hunting for a intake manifold. It was a square U shape, with legs about 4 or 5 inches apart. They gave a bag of stuff, and a squeeze thing that looked like a bigger unit you would use on babies and infants to clear nostrils with. About the only way I can describe it
Baggs is offline   Reply With Quote
