Old 01-09-2021, 12:48 PM   #1
CA Victoria
CA Victoria's Avatar
Default Crankshaft Flange Data
Looking for the flywheel mounting bolt and locator pin hole measurements in the flywheel. Measured mine, but would like to confirm with data from Ford drawings or from cad.
Thank you in advance....
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 01-09-2021, 12:58 PM   #2
Terry Burtz, Calif
Default Re: Crankshaft Flange Data
Flange Dia 3.998/3.999 inch
Bolt Circle Dia 3.249/3.251 inch
Dowel Pin Dia .436/.437 inch
Bolt holes 7/16-20 NF-3 thread
Terry Burtz, Calif is offline   Reply With Quote
Old 01-09-2021, 01:17 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
i have a crankshaft picture that has the bolt center diameter (and pins) as 3248-3.251 if that helps
