10-18-2020, 01:02 PM | #1 |
1937-1941 Pickup Box Bolts
Was cleaning up bags and boxes of old screws/nuts and bolts yesterday and came across some of the original box bolts from my '39. These are the ones that attached the box to the frame. I don't think these are readily available and wanted to post in case someone looking for these has questions about lengths. I didn't include the tapered ends of the middle ones in measurements but did have one of the angled spacer for the kickup area to give a reference for that. The reason the door handle is in the photos is because the shaft is the size needed to serve as a tool to remove these bolts as well as the anti-chatter rod bolts that have the square drive where the rods attach to the frame.
10-18-2020, 08:28 PM | #2 |
Re: 1937-1941 Pickup Box Bolts
You can buy any shape or length of bolts from McMaster-Carr
or Grainger. They come in steel or Stainless I always use SS G.M.
www.fordcollector.com |
10-19-2020, 08:58 AM | #3 |
Michael Driskell may have some use for this information since he now has the Ford Bolt business. I was recently at his business and I can tell you the bolt inventory and his knowledge of Ford bolts is very impressive.
10-19-2020, 10:52 AM | #4 |
