Old 05-20-2020, 03:01 PM   #1
George
George's Avatar
Default Ark-Les switch question
Hoping someone can tell me the bulb size used in these aftermarket switches that have the light socket located under the actuating knob. This would be on a 6V system.
George is offline   Reply With Quote
Old 05-20-2020, 03:04 PM   #2
alanwoodieman
Default Re: Ark-Les switch question
51 or 53
alanwoodieman is online now   Reply With Quote
Old 05-20-2020, 05:23 PM   #3
rotorwrench
rotorwrench's Avatar
Have you removed one to make sure it's not an LED? Incandescent bulbs are rapidly becoming museum pieces and the off beat tiny ones may be made of unobtanium.
Old 05-20-2020, 06:10 PM   #4
George
George's Avatar
There was no bulb in the switch. I found a #51 bulb in my stash and it drops into the space below the switch knob, but rattles around in the space when I shake the switch.
Question, is there some type of adapter perhaps that the bulb base fits into and drops into the space? I seem to be missing something here.
The inner diameter of the “bulb well” is around 3/8”. The #51 bulb base is slightly smaller than that.
Old 05-20-2020, 07:22 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
It sounds like the #51 bulb is the correct bulb.
It has a 9mm (.355) base diameter.
If the bulb engages correctly on the pins and center contact, just put a single wrap of masking or other tape around the base above the pins to reduce any perceived looseness.
Old 05-21-2020, 09:18 AM   #6
George
George's Avatar
Thanks all for your input on this.
Old 05-21-2020, 06:25 PM   #7
rotorwrench
There may have been a piece in there that deteriorated over time but I don't know. Maybe a spring? This was an old thread on the subject.
https://www.fordbarn.com/forum/showthread.php?t=205683
