Old 03-18-2021, 07:35 PM   #21
Bill OH
Default Re: 3.54 vs 3.25
I am running a Max 1 cam in a 221 driving a 3.54 with 6.00 x 16 tires and the sweet spot is at 65mph. I am running in flat county and the acceleration is good.
Bill OH is offline   Reply With Quote
Old 03-18-2021, 08:10 PM   #22
drolston
drolston's Avatar
I changed the 3.78 for 3.25 gears in my '41 coupe with a 284 inch motor and Schneider 248f cam and Offy 425 heads. I love the quieter and more economical cruise and with the torque of that 4.125" stroke engine, no problem getting rolling, even on a steep incline. I bought a transmission case to build a 15/29 for lower gears, but I think that transmission case will stay under the work bench.
Old 03-18-2021, 09:39 PM   #23
alanwoodieman
I run 3:25 in my 41 truck with a 51 merc engine, only problem is starting off on a big hill, need to ride the clutch to get going which is tough on the clutch but do like the gear on a road trip-
Old 03-18-2021, 09:48 PM   #24
tubman
tubman's Avatar
I have 3.55's in my '51 with a "warmed over" 255 ci Mercury. I find the car absolutely fine while driving around town, but I find myself trying to "grab another gear" on the highway. I plan on solving that by installing an overdrive transmission. I don't know their exact diameter, but I am running 2.25/75R15 rear tires. I believe that my '51 is about 300 lbs. heavier than a pre-war Ford.
Old 03-19-2021, 12:13 AM   #25
Tinker
Tinker's Avatar
I'd just setup to a 3:54 and see how it goes. Worked for years stock.
Old 03-19-2021, 02:38 AM   #26
flathead 39
flathead 39's Avatar
Thanks. Wow, Practically a perfect match! I'll definitely go with the 3.25.
thanks for the info!
Much improved since Henry sold it.
flathead 39 is offline   Reply With Quote
Old 03-19-2021, 02:46 AM   #27
flathead 39
Thanks to all for your responses, I was going back and forth but have decided on the 3.25. This forum is amazing!
Old 03-19-2021, 06:26 AM   #28
john in illinois
john in illinois's Avatar
I am very happy with 3.25s in my lighter roadster. I do have the low first and second. It has plenty of torque in 3rd ,which surprised me.Schneider 248F cam.
It sounds like your car would pull just fine .
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 03-19-2021, 10:18 AM   #29
flathead 39
John
Thanks, from the specs I got from the prev. owner, my cam is the Schneider P-3/8.
Old 04-24-2021, 11:39 AM   #30
gfriedr
Put an overdrive in it like a 700r
gfriedr is offline   Reply With Quote
Old 04-24-2021, 12:40 PM   #31
blucar
blucar's Avatar
I have to second, well almost, the above suggestion. A built 2004R would work better with the 3.78 ratio. The 2004R is basically the same size as a TH350.
An overdrive, be it a Columbia or an AOD, or a 5 spd T-5 is the better way to go.. My '36 has a well built 59AB with a 47-48 Columbia w/3.78 gears. the car runs very well on the street and/or highway. In my younger years I use to street race the car on a regular basis, very seldom got beat even against the stock tri-five Chevy's in the '50's.
I have 3.26 gears in my '39, however the engine is a 330 hp 350 w/700R4, the car is a rocket ship. Apples and banana's...
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 04-25-2021, 11:03 AM   #32
flathead 39
Actually, changing gear ratios is my only option. I want to keep it simple and keep the stock rear end and xmission. Have pretty much decided on the 3.54 as most of my driving is on back roads and surface streets (except for some interstate driving to get off this mountain).
Old 04-25-2021, 11:28 AM   #33
blucar
blucar's Avatar
To recap what I said earlier about installing an OD in lieu of trying to find a gear ratio that works under multiple conditions.
A late model Columbia, 46-48 will bolt right up to your stock 3.78 center section. The 46-48 Columbia's have electric over vacuum shifting which is very user friendly.
The 46-48 Columbia's are very strong compared to the 36-41 units, they do need a few modifications and are a little spendy, but when you take into consider the benefits of not having to modify the car and the flexibility of the multiple gears, the benefits are huge.
I have driven my '36 over 94k in the 68 years I have owned the car, never had any problems with the Columbia, blew out several transmissions street racing, due to missed speed shifting.
Old 04-25-2021, 11:30 AM   #34
19Fordy
19Fordy's Avatar
As a side note, it's intersting to note that:
"The maximum speed was 35 MPH until 1940 and was 50 MPH from 1941 until 1958 (excepting the national 35 MPH limit of World War 2). In California [Chartrain 2005], the maximum speed was 45 MPH from 1931 until 1941. In 1941 it was raised to 55 MPH."
Old 04-25-2021, 02:49 PM   #35
flathead 39
Yes and that's what my car was designed for.. the 1939 suspension, steering, etc is most comfortable at speeds under 55 mph, and so am I (in this car). The 3 speed & stock rear end is all I want. I bought the car more for nostalgia than anything else. My first car was a 40 Merc (1958-60) and this one takes me back there every time I drive it. But thanks for the comments & advice.
Old 04-25-2021, 08:44 PM   #36
JSeery
JSeery's Avatar
Man, that is a different world than I was around! Kansas didn't even have a speed limit until the 50s I think. It was what ever you felt was prudent under the conditions. It may have been earlier, I can't find a reference.
Old 04-26-2021, 03:41 AM   #37
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
My friend has a 40 Ford 2 door sdn. and he put 325 in it and they are super great. We live in hilly country and no problem. I wish I had put them in my 35 Ford pickup. No problem taking off. I was surprise how nice they are.
Old Redneck is offline   Reply With Quote
Old 04-26-2021, 07:48 AM   #38
Ford Freak
What is your 40 Ford friend running for an engine? If modified, how much?
I was thinking of putting 3.50's in my '37 w/stock 85 hp., 24 stud engine,
w/27" tall tires. Now, I am thinking that 3.25's might be better. Hmm........
1952 Ford F1
1965 Ford Falcon Sprint
2007 Ford Mustang GT
Ford Freak is offline   Reply With Quote
Old 04-26-2021, 09:44 AM   #39
flathead 39
OK, so now you got me looking at the 3.25 again.. I've been bouncing between that & the 3.54.. Maybe by the time I'm ready (any time now) I'll be able to make up my mind. Going over the rpm/mph chart for both, I think 3.25 would be just right. Thanks.
Old 04-26-2021, 12:25 PM   #40
35fordtn
35fordtn's Avatar
I have the 3.25 and the 15/29 transmission gears in my 36 and so far I LOVE it..
