03-11-2021, 11:29 AM | #1 |
Mild lowering, 1941
Hi, I'm trying to bring my newly acquired '41 sedan a little lower to the ground without affecting the ride or basic handling characteristics. Thought I could
kill two birds with one stone if I replaced the front and rear springs with Posies 2"dropped springs while I replace the shackles and bushings. I'm aware of dropped axles and lowering blocks, but don't want the work involved with such modifications. Just want to keep it simple, drop the car about 2" and possibly improve the ride. Bad idea??? Thanks for any inputs, Tony |
03-11-2021, 11:32 AM | #2 |
Re: Mild lowering, 1941
Longer spring shackles also work.
03-11-2021, 01:21 PM | #3 |
I'm going with reverse eye main leaf up front and a pair of longer shackles with a panhard bar to stop the swing in the rear on my 41 pickup. A couple of guys have said posies spring don't always drop the car as much as advertised do to old spring sag/wear. That is why I'm just changing my main leaf to reverse the eyes. I should get about two inches drop from that in the front and by increasing my shackle length by in the rear this towering pickup should come down to earth. Best of luck on your sedan. Tim
03-11-2021, 02:06 PM | #4 |
Reference this thread.
https://www.fordbarn.com/forum/showt...light=drolston Beware that 1941 was a unique transition year for the front suspension. Neither of the two Posies springs are exactly correct. I had to fab longer shackles to get the shackle angle right. Which is important for handling. |
03-11-2021, 02:08 PM | #5 |
Also check this thread. More detail on Posies.
https://www.fordbarn.com/forum/showt...ghlight=posies |
03-11-2021, 11:52 PM | #6 |
03-11-2021, 11:59 PM | #7 |
On the front I'd consider a drop axle over all other options. It does involve, maybe messing with your steering arm and track bar. If you reverse the eye of the current spring you might get there. But if you buy a new reverse eye it probably has more arch then your current old spring. Think I got about the same with my 38 on the rear, added 2" drop shackles also. Great tight spring though. For the rear you can just use some lowering shackles.
Who knew 2" is such a pain and requires so much work. It's easier just to leave it alone and be happy you have some room to roll under it to change the oil. Maybe some rear shackles and a some rear fender skirts. Mild tail dragger vibe. . Last edited by Tinker; 03-12-2021 at 12:14 AM. |
03-12-2021, 06:24 AM | #8 |
You can lower the back with longer shackles, but it will be at the expense of handling.
Without a track bar in the rear, longer shackles will give you handling like a labrador on linoleum. Ask how I know. On my 41 I wound up de-arching the rear spring and reversing the eyes for a 3 - 4 " drop. This way I kept close to stock handling with the drop I wanted. I'm running 6.50 X 16's. Only slightly bigger than stock, but on the front there is not a lot of fender clearance. If you plan lower the front a lot keep this in mind. Last edited by fortyonerag; 03-12-2021 at 10:49 PM. |
03-12-2021, 09:26 AM | #9 |
i would also dearch the springs.
03-12-2021, 11:21 AM | #10 |
This is my 47 I had the main leaf reversed and flattened, shackles and I took out a few of the top leafs
03-13-2021, 12:56 AM | #11 |
Absolutely beautiful ride
"I have built my organisation on fear"..Al Capone. |
03-13-2021, 01:26 AM | #12 |
It seems like you don't see a lot fatfender coupes around. Low production numbers or something. Hombres yours has always been a favorite of mine for a long time. Never had the pleasure of seeing it in person however.
03-13-2021, 01:51 AM | #13 | |
Here's where all of your fat-fendered coupes went.....EVERY Saturday nite across America, one by one....GONE! DD |
03-13-2021, 07:44 AM | #14 |
03-17-2021, 11:24 AM | #15 |
Once again, thanks to all who responded to my query. I will definitely consider all options...
Tony |
05-21-2021, 12:02 AM | #16 |
Thanks so much .. hope to show it to you some time
05-21-2021, 12:02 AM | #17 |
thank you
05-21-2021, 12:03 AM | #18 |
Much appreciated
