Old 07-23-2012, 12:19 PM   #1
steamgas
steamgas's Avatar
Default Need a really good crankshaft grinder
I am looking for someone on the east coast that can grind a model a ford crankshaft to factory spec's.i have tried who clame too be the best their is and they all fall short according to the factory spec's when it comes to the t.i.r.can someone please help me.
steamgas is offline   Reply With Quote
Old 07-23-2012, 12:28 PM   #2
Kohnke Rebabbitting
Default Re: Need a really good crankshaft grinder
Places for J and M Machine co. near
J&M Machine Company: Engine Rebuilder
J and M Machine are in southbourogh, Ma. Phone 508-460-0733
Kohnke Rebabbitting is offline   Reply With Quote
Old 07-23-2012, 06:07 PM   #3
Purdy Swoft
Purdy Swoft's Avatar
I haven't tried this soarce but it was given to me by a guy at a swap meet in South Carolina.
Crankshaft rebuilding service standardcrankshaft.com or phone 704-392-4371 Charlotte North Carolina It was said that they can rebuild any crankshaft. Good luck.
Old 07-23-2012, 06:32 PM   #4
Mitch//pa
Ck out this place also
http://www.schwalms.com/
Old 07-23-2012, 08:58 PM   #5
no6
no6's Avatar
X's 2
no6 is offline   Reply With Quote
Old 07-23-2012, 09:39 PM   #6
columbiA
Make sure you have the correct radius ground on the brgs or you may be looking at a broken crankshaft one day.
columbiA is offline   Reply With Quote
Old 07-23-2012, 10:43 PM   #7
cabrioletgalaxie
If you are talking factory specs don't you need someone who can build up the journals with metal deposition and then turn them down to factory specs? Otherwise when grinding you would by definition be making them smaller in diameter.
cabrioletgalaxie is offline   Reply With Quote
Old 07-24-2012, 06:20 AM   #8
Kevin in NJ
Here are some notes on crank shafts:
Crank grinding
Kevin in NJ is offline   Reply With Quote
