11-13-2011, 01:28 PM | #1 |
Best way for my wife to replace Hi Comp Head Gasket?
What is the best gasket replacement for a high compression head?
When my wife replaces the gasket, any special tips or tricks we should tell her? Thanks, Pepe Loco Austin |
11-13-2011, 01:42 PM | #2 |
Re: Best way for my wife to replace Hi Comp Head Gasket?
Hmmmmm could be on thin ice here. Mine uses Felpro copper ones with spray on copper coat, An expensive meal out also helps,
11-13-2011, 01:49 PM | #3 |
You should also make sure to fix the "WHY" you blew the head gasket.
Is your head warped? Is it a BF head? I just did mine and found the center was low. Had to get it resurfaced. I also searched the net and found others with warped heads that had to do the same thing.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
11-13-2011, 02:13 PM | #4 |
You need to supply her with tools and equipment that she is used to working with, a kitchen table instead of a work bench, Brillo pads, etc. I recommend keeping her away from knives and other sharp instruments! :-)
11-13-2011, 03:21 PM | #5 |
You must have a great lady there, as I've only known one who wrenched model As! Best tip I can give is to make every thing clean...and ensure that it's flat! Good luck to you both!
Prior to installing studs, vacuum stud holes of any debris. Hand thread the studs into the block until bottomed out. A little 'never seize' on the lower threads will help accomplish the hand threading and make studs easier to remove , if necessary. If you suspect a water leak at any particular stud, some use a small amount of gasket sealer on that stud lower threads. Head removal can be a heavy task and cause strained muscles. Parts suppliers sell spark plug hole adapters which you can attach a hoist or pulley setup to remove heavy/stubborn/heavy heads. warning: if you choose to use compressed air to blow metal chips/other debris, in addition to vacuuming or in place of....wear SAFETY goggles. Also, do NOT blow 'stuff' down towards cylinders/rings/pistons. Last edited by hardtimes; 11-14-2011 at 03:05 PM. Reason: add...... |
11-13-2011, 03:31 PM | #6 |
Torque the head as shown, re-torque the head after a hundred miles and then torque again. I am sure somebody will add the stuff I forgot.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
11-13-2011, 06:45 PM | #7 |
Daaaaaaaaaang, sure sounds like you got her trained right. How did you do that?
11-13-2011, 11:05 PM | #8 |
like the old CHARLIE WALKER song ,tell her lies and feed her CANDY .
11-14-2011, 12:56 AM | #9 |
Torque wrench, socket set (3/8 to 3/4), the U shaped wrench for the nut under the distributor,anti seize for stud threads, pliers for cotter pins, gasket scraper, screw drivers for removing distributor, combination wrenches (3/8 to 3/4), gasket sealer,cam wrench for distributor, engine crank for setting the points, rags, solvent, pry bar, wire brush, thread chaser are most of the tools she will need.
You are lucky to have help like your wife. Mine will help sometimes but it she would just as soon not. She always has to change clothes and wants gloves etc. I am sure I forgot something but somebody should add something. Spark Plug Socket
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. Last edited by sturgis 39; 11-14-2011 at 01:03 AM. Reason: Added Spark Plug Socket. |
11-14-2011, 12:43 PM | #10 |
I "vacuum" the hole with an air nozzle that has a 3/16" copper tube, about 6" long. Stick it all the way into the hole and blow out the debris.
11-14-2011, 03:25 PM | #11 |
I am getting ready to install a Snyder 5.5 head....all good advice..
11-14-2011, 03:54 PM | #12 |
We had a couple of Snyder heads bought by local members that were to say the least rough. The casting was not what we had seen in the past. They made them good but how did they go out the door like that.
I could not be happier with mine. When you can accelerate up a hill you know your doing good.
Oklahoma City Model A Restorers Group. |
11-14-2011, 04:22 PM | #13 |
Actually I would use the head gasket meant for High Compression heads, Snyders and all the other suppliers have them. They recommend them for High Comp heads
