01-26-2018, 02:09 PM | #1 |
Fuel pump push rod
i just inserted the fuel pump rod down onto the cam lobe but there is no lift on the rod. what am i doing wrong?
01-26-2018, 02:44 PM | #2 |
Re: Fuel pump push rod
sorry guy's i feel like the man in Hawaii who pushed the wrong button and caused a false alarm for a nuclear attack.when i reamed out the bushing for the push rod i never went all the way thru. unlike the man who pushed the wrong button,i will answer any and all questions you may have.
01-26-2018, 08:21 PM | #3 |
What type of bushing are you using? The ones I have messed with are hardened and would be difficult to ream.
01-27-2018, 06:59 AM | #4 | |
When pressed in place they will swage down to a smaller ID and may or may not require reaming to accommodate the 3/8" push-rod.
01-27-2018, 09:03 AM | #5 |
Interesting, does't look like they have the oil groove as well.
01-27-2018, 09:18 AM | #6 |
01-27-2018, 10:33 AM | #7 |
I guy might be able to finish reaming it but it's going to be tricky with the cam in there. Turn the engine upside down in a stand and use grease on the reamer to catch the metal particles. The reamer would have to be the correct finish size with multi flutes and have a flat face on the end that goes in the bore. Ream a little ways then rotate it back out for cleaning & re-lube then repeat as necessary until through. Make sure the cam lobe is all the way down on the stroke cycle.
