Old 06-21-2016, 02:26 AM   #1
Gerryde
Default 1928-29 Qual radiatorcap breakdown
Hi folks I have a 1928-29 qual radiator cap and when i got it ,it was in peaces ,i have the bits and not sure how it works ,If I screw the cap onto the radiator,then I can not get the Qual to tightenup onto the screw part of the cap.
would anyone have a pic of the bits of the cap and which way the parts go.
Many thanks Gerry (NZ)
Gerryde is offline   Reply With Quote
Old 06-21-2016, 11:37 AM   #2
captndan
captndan's Avatar
Default Re: 1928-29 Qual radiatorcap breakdown
Make sure you have the correct year cap. They are different. Do you have the two brass tabs and cap screws inside the cap?
captndan is offline   Reply With Quote
Old 06-22-2016, 04:02 AM   #3
Gerryde
Hi the only thing I have is the quail and the cap,looking from the bottom of the cap there is i screw bolt that goes through the cap and into the bottom of the quail. If some one had a pic off the underside i would be able to see if anything is missing. .Cheers Gerry (NZ)
Old 06-22-2016, 05:27 AM   #4
Steve Wastler
Steve Wastler's Avatar
Sounds like yours is cobbled together with a regular cap and the bird with a bolt into the thermostat hole of the bird.
Steve Wastler is offline   Reply With Quote
Old 06-22-2016, 06:30 PM   #5
Gerryde
Hi ill try and get some pics for you to see.
Cheers Gerry (NZ)
