05-02-2015, 07:18 PM | #21 |
Re: A vs AA Transmission
You should see a casting date on the Transmission case. Mine is on the drivers side near the Top. Mine was cast 2-13-31.
Since yours has the threaded style shifter cap it is the later one. I'm not sure when they changed. I do know the shifter cap that is held in by the Pins is considered the early AA Trans. I believe they came out at the very end of 1929 and only in AA Trucks. They were a common Dealer retrofit into Model A's especially in the Pickups. They are the Beefier Truck Transmission, very Heavy Duty. They made them well into the 1950's the gears that is. The cases changed often.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
05-02-2015, 07:33 PM | #22 |
could this be a 32 AA transmission? How would I tell?
05-02-2015, 07:51 PM | #23 |
It's not a 32 trans, the 32 and later have no provision for the clutch
and brake pedals. Bob |
05-02-2015, 08:37 PM | #24 |
I found a little cast tag that reads...7--3.. could that be July of 33, or is that the wrong tag? There is a mark next to it that looks a little like a @ but about 5/8" diameter..
05-03-2015, 11:55 PM | #25 |
Here is a photo of mine.
05-04-2015, 08:37 AM | #26 |
Still looking! |
05-04-2015, 08:55 AM | #27 |
Here is the tag that is on my transmission..
05-04-2015, 12:50 PM | #28 |
It looks like he's got the older AA trans with the 3 speeds + hi/lo foot lever. Maybe if he puts it in high and leaves in there.
-Rob 1929 Fordor Leatherback |
05-04-2015, 12:55 PM | #29 |
There is no foot lever..but I've seen pictures...but where would the foot lever have connected to the transmission? Did they use the PTO access? The battery is right there on the driver side...so no room now....
Thanks! |
05-04-2015, 02:10 PM | #30 |
There would be a HI-LO tranny in place of the intermediate shaft, right behind the main tranny.
05-04-2015, 02:18 PM | #31 |
He's got a Model A not an AA.
Bob |
05-04-2015, 02:31 PM | #32 |
05-04-2015, 02:47 PM | #33 |
05-05-2015, 10:25 PM | #34 |
You remember the motor mount with the 5/16 plate on top and no bolts to the flywheel housing?
New parts came today and the mounts have been replaced and the bolts installed... The bottom bolt was just missing, the top bolt was broken almost flush with the case so I Dremeled a groove in the stub and took it out with a screwdriver....easier said than done but it is done..finally... |
05-06-2015, 01:09 AM | #35 |
That looks good!
05-06-2015, 07:18 AM | #36 | |
It looks like at least one of the bell housing bolts has a rounded head, rather than a flat head. It might have been switch with another engine bolt of the same size. The side water inlet has rounded head bolts, and the timing cover does also. |
05-06-2015, 08:50 AM | #37 |
The 4-speed transmission rear bearing retainer should look like the one in the photo below. This is for the AA chassis. The A chassis used the same retainer except it was about 1/8" less in thickness.
The bearing retainer shown in the 1955cj5 photos is not the A chassis part. Also, there was not support used as shown in one of the 1955cj5 photos.
[email protected] - email contact https://aafords.com Ford Model AA Truck Club @ aafords.com Last edited by Neil Wilson; 05-06-2015 at 08:56 AM. |
05-06-2015, 11:39 AM | #38 |
Vince has information and pictures of the parts to install the
4-speed in the Model A on his web site. http://www.fordgarage.com/pages/aafourspeedachassis.htm Bob |
05-06-2015, 12:06 PM | #39 |
Thanks for the photos and information....
Right now the rear bearing retainer is a mystery...I don't thing it looks like the AA retainer but I'll go look more closely.... And today I think the support that is hanging on the crossmember will come out..... There is pressure on it so it is supporting weight....I just hope the transmission does not rest on the brake cross shaft once the support is removed..... |
05-22-2015, 08:44 PM | #40 | |
Been mulling changing back to a 3-speed....were there different torque tube lengths? Measured a 1930 today and it was 49 3/16 from the back edge of the clam shell to the front of the flange at the differential.....mine measured 49/1/2"....does that sound right, or has the tube been altered? Randy |
