Old 12-02-2013, 02:34 PM   #1
steamgas
steamgas's Avatar
Default off topic subject
has anyone ever made a clutch disk assembly that has shoes on it that can be repaced with out removing the motor or transmitiom from the car or truck of any year or make?
steamgas is offline   Reply With Quote
Old 12-02-2013, 03:10 PM   #2
Terry,NJ
Terry,NJ's Avatar
Default Re: off topic subject
Saab 900! You put a new disc in the top. Just remove the top cover, slide the splined shaft forward, disconnect the hydraulic line that operates the clutch, and unbolt the clutch, all with out creeping underneath! If the shaft didn't stick in the forward Chain sprocket (Chain sprocket???) it was about a hour. The Saab 900 drove through a chain. It was a very interesting and reliable design.
Terry
Terry,NJ is offline   Reply With Quote
Old 12-02-2013, 05:20 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Terry
I've done several of those, Terry. Pretty trick design. Just compress the pressure plate & block it with a piece of fan belt, laid in backwards. Note: You can NEVER bleed the clutch hydraulic cylinders with your foot!! With a pressure bleeder, it only takes 3 nano-seconds. Bill W.
"THE ASSISTANT GURU OF STUFF"
