Old 05-25-2013, 01:13 PM   #1
steamgas
steamgas's Avatar
Default Decking a model a block
is there a process that one must follow to properly deck a model a block?
need help understanding what to do.i have my own machine shop just need
the information.
steamgas is offline   Reply With Quote
Old 05-25-2013, 05:11 PM   #2
KR500
KR500's Avatar
Default Re: Decking a model a block
If you are doing just a skim cut to return the deck to a flatness across its surface , a water grinder with enough travel in the X axis and a height that you can get the wheel up to, even if you use a well worn and small grinding wheel should do it. Just check that block is relatively parallel across the top, not tipped resting on burrs in the pan rail area. Good luck.
KR500 is offline   Reply With Quote
Old 05-25-2013, 11:51 PM   #3
31 A4door
Yep I have done a couple of T block on our Blanchard grinder at work. Just make sure you have no burs on the bottom and dont grind the bottom 1st as you move the center line of the crank.
31 A4door is offline   Reply With Quote
Old 05-26-2013, 11:57 AM   #4
noboD
I would tram the head first.
noboD is online now   Reply With Quote
