01-24-2021, 01:14 PM | #1 |
Bridge washer installation
Is the bridge washer necessary if using a Coker inner tube that comes with the metal stem already attached or is the primarily used if cutting in your own metal stem to replace the rubber one?
01-24-2021, 02:01 PM | #2 |
Re: Bridge washer installation
Brattons metals stem inner tubes come with a bridge washer and nut. What does Coker say about their metal stem tubes? Are we comparing apples to apples here?
01-24-2021, 02:28 PM | #3 |
It helps center the valve stem in the groove and keeps it from turning when the rim nut is installed.
I know the voices aren't real but damn they have some good ideas! |
01-24-2021, 03:02 PM | #4 |
