Old 05-13-2020, 02:46 PM   #1
Clem Clement
Clem Clement's Avatar
Default seat adj. '40 Merc 4 four convert
40Merec front seat has adj forward and back. Also I can raise/lower the mount by changing the bolt hole. Both sides are in the top holes. Front and back, the driver side is full forward and the passenger side is full back. It looks live the up/down bolts use a trapped nut. True? Probably the same for as Ford.)
I'm 6'3". Im thinking I can gain room by moving the bench seat full down/back
