01-02-2016, 08:24 PM | #1 |
'39 Ford DeLuxe steering wheel rim paint
I am looking for the correct type and color paint for the rim of a '39 Ford DeLuxe steering wheel. The only information I have is the name of the color (Cameo Gray) Ford used. My wheel is in very good condition, but the outer rim needs to have the incorrect color removed. I then, also need to know how to remove this paint without damaging the hard rubber rim.
01-02-2016, 09:40 PM | #2 |
Re: '39 Ford DeLuxe steering wheel rim paint
I would just sand it and repaint it with the correct color
01-02-2016, 10:22 PM | #3 |
I have the same question. The paint is all off of mine. What was used to paint these wheels?
01-03-2016, 08:46 AM | #4 |
Here's a pic - the true color was more like rim closest to shift knob, the flash lighted pic
I recently refurbished and painted it (diffrent color) came nice. I would suggest you just sand it w over a thousand grit and then re paint it. Of course wheel needs to be out of car. Last edited by adileo; 01-03-2016 at 09:34 AM. |
01-03-2016, 09:48 AM | #5 |
Obviously, utilizing a photograph to duplicate a color is perhaps one of the poorest ideas to embrace.
If at all possible, find a place where the correct color has yet to be worn away and / or faded significantly from sun exposure, etc. I may be able to help with formulas I have derived from authentic pieces.
01-03-2016, 04:41 PM | #6 | |
01-03-2016, 04:42 PM | #7 | |
01-03-2016, 05:22 PM | #8 |
Let me look if I still have it. This particular car I had done about 4 years ago.
01-04-2016, 08:43 PM | #9 |
Do the colors on your photo match the actual colors of your wheel? The photo shows the rim darker than others I've seen and the hub looks nearly black.
Thank-you, John |
03-18-2024, 05:04 PM | #10 |
Would someone direct me to supplier and/or formula for oyster gray and Zephyr gray paint? 39 DeLuxe getting a beauty treatment! Thank you.KurtDouglas
