Old 04-24-2015, 07:48 PM   #1
Fred K-OR
Fred K-OR's Avatar
Default Which way to install manifold gaskets???
Attached is a picture of a two piece copper manifold gasket. The top one shows a wider ring around the hole while the lower one has the narrow ring. Which side goes against the block? Please help this guy that knows nothing about what he is doing. Thanks
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 04-24-2015, 10:24 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Which way to install manifold gaskets???
If the ring is on both sides it makes no difference. If the ring is on one side it seems common practice is to place the ring away from the block.
Old 04-24-2015, 11:12 PM   #3
jax55
jax55's Avatar
I agree with Mike V. At least that is the way I install them.
jax55 is offline   Reply With Quote
Old 04-25-2015, 05:30 AM   #4
34Pietenpol
34Pietenpol's Avatar
From a practical point of view: Mic the ID of the block openings and the manifold openings. One set usually has a little larger ID than the other. To get the best seal, place the gasket with the larger ring bearing surface against the largest opening. Ideally, you would port the openings to match to maximize smooth flow.
34Pietenpol is offline   Reply With Quote
Old 04-25-2015, 06:15 AM   #5
James Rogers
James Rogers's Avatar
Mike V is correct.
Old 04-25-2015, 09:24 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Gregg & I pondered the BIG & the LITTLE rings??? We put each one opposite, to see WHICH one failed first! Haven't run the car yet. "MAYBE" NEXT JUVEMBER???
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-25-2015, 10:05 AM   #7
Fred K-OR
Fred K-OR's Avatar
Thanks guys. Have to get the old bones out to the shop now to do it!
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 04-25-2015, 11:14 PM   #8
Mike V. Florida
Originally Posted by James Rogers View Post
Mike V is correct.
I'm showing this to my wife!!
Old 04-26-2015, 05:37 PM   #9
Fred K-OR
Fred K-OR's Avatar
Thanks again guys. Got it installed and after getting an exhaust hookup leak at the manifold fixed, the job was finished. Could not find any leaks after getting it installed around the intake ports.
But is still has not solved my problem with a random miss while idling. So back to the drawing boards on that problem. Think it sounds to me like an electrical problems. Just a guess from a guy that knows little about this sort of thing. So I think the next step is to change out the distributor with an extra one I have that I know is good.
Anyway, thanks again guys.
Fred Kroon
1929 Std Coupe
1929 Huckster
