04-24-2015, 01:56 PM | #1 |
rear hub puller
Does anyone rent a rear hub puller that will work on model A's? Re-packing the front was easy yesterday.
04-24-2015, 02:14 PM | #2 |
Re: rear hub puller
I've used a three pronged puller rented from my local auto parts store. Actually it was loaned. They charge for it in case you break it or don't bring it back but refund your money when you return it.
04-24-2015, 02:17 PM | #3 |
Re: rear hub puller
I just bought one from Mitchell. They are under $100 and will work for both kinds of hubs.
(Owning a Model A is just an excuse to buy more tools!)
04-24-2015, 02:35 PM | #4 |
Re: rear hub puller
here is my puller for :::
rear drums / hubs any type of bearing on differential, trans, axle, and on & on steering worm and whatever else you can think of the threaded rods screw into each other for super long lengths this is snap on,,,,pricey but will last a lifetine.. the cheap sets use at your own risk Last edited by Mitch//pa; 04-24-2015 at 03:25 PM. |
04-24-2015, 03:17 PM | #5 |
Re: rear hub puller
I picked up this monster (very heavy and very heavy duty!) cause the price was right. Has anyone had any experience with this type of puller?
04-24-2015, 04:20 PM | #6 | |
Re: rear hub puller
Charlie Stephens |
04-24-2015, 04:36 PM | #7 |
Re: rear hub puller
pgerhardt...that is a Snap-on Dreadnaught puller. The 3 arms are for the lug patterns like Mopar and Studebaker that were a bit smaller than the For 5 1/2" circle.
It came with two extra arms (arms snap out with puller relaxed) to pull Ford hubs from the groove, same general approach as a Ford KRW puller. This made the pull much safer for the hub and also made it fully usable on the '36-9 Fords with gigantic pattern. The large Ford bolt circle and the very high load put into the hub/axle joint by proper tightening makes it possible to permanently warp hubs and even split brake drums on really tight pulls. Ford expected the hubs to be pulled from central ring, and the good tool companies like KRW, Snap on, and Plomb all sold rigs that could do that. KRW was Ford groove only, Plomb and Snap on made their generic 3 arm pullers with special rigs for Ford use. |
04-24-2015, 05:03 PM | #8 | |
Re: rear hub puller
04-24-2015, 05:28 PM | #9 | |
Re: rear hub puller
If I did work on another AA, I'd probably become a member of AA. |
04-24-2015, 07:25 PM | #10 |
Re: rear hub puller
I bought a Mitchell and it works great. You will need it anytime you should grease your rear end bearings and they should be greased. Therefore it makes sense to buy one. I think I paid $50 or $60 bucks for one at Bert's(I think)-sorry Steve if I miss quoted.
Fred Kroon 1929 Std Coupe 1929 Huckster |
04-25-2015, 05:21 AM | #11 |
Re: rear hub puller
I used one like that that I borrowed from a neighbor and it worked great. A hotrodder in town here has a smaller one that has worked, too.
04-25-2015, 06:48 AM | #12 |
Re: rear hub puller
Thank you.
04-25-2015, 05:24 PM | #13 |
Re: rear hub puller
that is like the one I use, I have never found any hub that it wouldn't fit or pull
