Old 02-14-2024, 03:58 PM   #1
svmsr1044
Default 56 Fairlane Wheels
I need 4 OEM style wheels for my 56 Fairlane Sunliner, are Vintique wheels any good? Any recommendations?
Thanks, Steve
svmsr1044 is offline   Reply With Quote
Old 02-14-2024, 06:05 PM   #2
miker98038
miker98038's Avatar
Default Re: 56 Fairlane Wheels
Go over to the HAMB and search Vintique, you’ll get a bunch of answers.
56 Ford wheels had the small center opening and most later wheels had a larger one. It’s not a problem to fit later wheels, but that will be a difference. You’ll have to ask if the full caps or center caps will fit the new wheels if you intend to use them. So, wheels that will bolt on? Yes. Actual OEM ? Probably not, but ask.
miker98038 is online now   Reply With Quote
Old 02-14-2024, 06:31 PM   #3
KULTULZ
KULTULZ's Avatar
Question Re: 56 Fairlane Wheels
Are you looking for correct factory wheels as for a restoration/correct appearance?
There was just a discussion on this not long ago-
https://www.fordbarn.com/forum/showthread.php?t=333667
KULTULZ is offline   Reply With Quote
