Old 07-19-2020, 04:57 PM   #11
Pete
Pete's Avatar
Default Re: Let's build a drag race 8BA engine
Originally Posted by HopRod View Post
Who can do a welded stroker in this area? Not sure what the cost would be, but seems very labor intensive. Cost maybe between a Moldex and an Eagle crank?
I am convinced to use H beam rods, so need to do some research on those.
I don't have copper brake lines, they are Ni-Copp, a Nickle/copper/iron alloy that is fuly DOT approved.
Thanks for info Pete
I don't know who is doing welded cranks now but I used to get them from Hank the Crank. Whatever crank you choose, when you balance it, you want to make the bob weight as light as possible.
Better make sure the racing association rules are ok with that brake line material. You are not racing with the DOT.
Here is a pic of what can be done with Cat H beam rods to lighten them.
