Old 01-24-2021, 01:43 PM   #1
shoe box Jack
Default standard ford with a 331 rear gear
My friend has a 1950 ford he would like to try a 331 gear out of a 51 automatic ? will it be to much gear? the 50 is stock. thanks for any info. Jack. the car has a 3.78 now,
shoe box Jack is offline   Reply With Quote
Old 01-24-2021, 08:00 PM   #2
JWL
Default Re: standard ford with a 331 rear gear
If everything is in decent condition and the terrain is reasonable it will work great. I often start with 2.23 gearing and just a bit of clutch slip makes it simple. The 3.31 should be even better.
JWL is offline   Reply With Quote
Old 01-25-2021, 08:05 AM   #3
shoe box Jack
Thanks JWL for the info. we are going to try it this spring. Jack.
