Old 01-17-2021, 03:59 PM   #1
steve hackel
steve hackel's Avatar
Default Now that I found my pump, anyone know of a kit?
Thanks to the Barn members I was able to locate the LB oil pump
for a modification project to be used in my 4 cylinder B' engine.
So far I have not been able to locate anyone that sells a rebuild kit
for these LB oil pumps (gears & shaft) and have tried the major
suppliers, but with no results. Does anyone know of a source for
the kits that i need? Thanks, Steve
steve hackel is offline   Reply With Quote
Old 01-17-2021, 04:12 PM   #2
jimTN
Default Re: Now that I found my pump, anyone know of a kit?
If there are no circles cut in the housing or base, no rings wore on the shaft, then it does not need rebuilding.
jimTN is offline   Reply With Quote
Old 01-17-2021, 05:27 PM   #3
cas3
i agree. if not worn out, then just new bushings for the shaft would all that is necessary. the bottom cover can be flipped over too for a new surface. smooth it up with 300 wet on a flat surface like glass or a saw table
Old 01-17-2021, 09:18 PM   #4
The Lucky Star
Steve,
I'm not familiar with these. Can you post a few photos of one please?
Thanks!
The Lucky Star is offline   Reply With Quote
Old 01-18-2021, 05:26 PM   #5
FritzJr
FritzJr's Avatar
Here is an exploded view:
FritzJr is offline   Reply With Quote
