12-08-2020, 04:22 PM | #1 |
Distributer Condenser and Points
My Model A uses the standard Model A distributor but with the modern condenser mounted on the top side of the upper plate and modern point set. What do I ask for at the NAPA store to replace these items? Thank you, Ed
12-08-2020, 05:15 PM | #2 |
Re: Distributer Condenser and Points
Does the Snyders kit for a modern distributor work? PN A-12127-RKM.
12-08-2020, 05:17 PM | #3 |
They also have just the modern plate for about half the money. See A-12151-C
12-08-2020, 05:22 PM | #4 |
Why not call up Bratton's and they will send you the correct parts...You'll have them in a couple of days 800-255-1929 or Arizona Model A 480-782-0266. If they have two quality levels, purchase the good stuff...Ernie in Arizona
12-08-2020, 05:33 PM | #5 |
Ask for a set of points for any 1957 and up Ford V-8 until they stopped using points. Mustang, Fairlane, all use the same points in the V-8s
12-08-2020, 05:40 PM | #6 |
12-09-2020, 09:15 AM | #7 |
Not sure about the points, but the condenser at NAPA is an Echlin FA-82. I learned that part number sitting on my running board at the side of the road.
Marty |
