Old 07-27-2020, 09:37 PM   #1
PeteVS
PeteVS's Avatar
Default Use of a MIG welder for other purposes?
I wound up bolting the frame for my Model A project together because I just wasn't getting any luck with riveting. I was TOTALLY unable to do them cold and went to the oxy torch. That heated them up good but by the time I got them placed, they had cooled. Then, I tried heating them in place. Only the tip of the rivet got hot and there was no expansion down in the hole when we hammered on them. Now, I'm wondering if I could hold the rivet in place with a brass bolt with a ground connection and place the tip of the welder on the other end. Should I be able to get enough current through the rivet to heat it properly in place? Also, could a MIG welder be used to heat metal for shrinking? (I talking about not having any welding wire involved.)
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 07-27-2020, 09:52 PM   #2
JSeery
JSeery's Avatar
Default Re: Use of a MIG welder for other purposes?
Not sure I understand how a MIG would work without welding wire? There is no heat involved with the MIG handle, just wire and shielding gas. The heat is produced by the current flow from the welding wire to the surface being welded. It is the same principle as a stick arc welder, the wire replaces the stick. So the question (to me) sounds like can you use an arc welding to produce heat without a stick in it? Or can you use an arc welder to shrink metal if I don't use the stick? Just don't understand the question.
Old 07-27-2020, 10:00 PM   #3
Bob C
I did something similar with my TIG welder.
Old 07-27-2020, 10:01 PM   #4
JSeery
JSeery's Avatar
A TIG yes, but how would that work with a MIG?
Old 07-27-2020, 10:31 PM   #5
deuce_roadster
deuce_roadster's Avatar
I think you could do it with 2 people. There is a company called "Big Flats Rivets" and at Hershey I bought rivets and bucking tools and different tools that go in an air hammer to either make a waffle or rounded rivet end. If you use oxy acetlyene and heat the rivet slowly in place you can get the entire rivet red hot, at this point, have your helper buck the already formed head and then with an air hammer form the other end and if the entire rivet was red hot, the center would swell too. Call Big Flats and ask for their advice, I am sure you won't be the first to ask. They are in NY Phone:
(607) 562-3501 Good luck, Maybe Google them, their website may have instructions
I just went to their website and they have good instructions...
Old 07-27-2020, 11:02 PM   #6
uncle buck
uncle buck's Avatar
http://bigflatsrivet.com/
uncle buck is offline   Reply With Quote
Old 07-28-2020, 01:47 AM   #7
Smitty
Smitty's Avatar
If doing frame rivets you need a 3x or 4x rivet gun, a friend holding a buck, an acetylene torch. I have riveted cross members in my Model A with excellent success. Yes see above post Big Flats Rivet will help you out.
Can buy used rivet gun (not air hammer, they are different) on the bay.
Smitty is offline   Reply With Quote
Old 07-28-2020, 05:10 AM   #8
JWL
I might like to try making a carbon rod "tip" to screw on the MIG gun in place of the contact tip. I'm sure it would work up to a point.
JWL is offline   Reply With Quote
Old 07-28-2020, 05:27 AM   #9
Tim Ayers
I’ve read a few times that the rivets should be annealed first before setting them. The article suggested placing them in a fire wrapped up in tin foil.
Old 07-28-2020, 05:58 AM   #10
PeteVS
PeteVS's Avatar
I was thinking that if I could get enough current (amps) to pass through the rivet, it would get hot by resistance, not by an arc. I think I'll have to dig up some info on resistance of steel and see what I can find.
Old 07-28-2020, 08:29 AM   #11
Zeke3
Zeke3's Avatar
See post #29 in the attached link about using an arc welder to heat the rivet. I haven't tried it yet.
https://www.fordbarn.com/forum/showt...hlight=cutting
Zeke3 is offline   Reply With Quote
Old 07-28-2020, 08:41 AM   #12
tubman
tubman's Avatar
I think this is a bad idea right from the start. It is completely outside of the function of a MIG welder and I don't see any easy way to make it work. Even if you could get it to work, I would thuink you would have a real good chance of doing permanent damage to you MIG welder. If you want to do something like this, get a stick welder (either a used transformer unit ot one of the new inverter units from China). I have one and it is a very well made unit. Then get a carbon arc torch; them suckers throw a lot of heat.
Old 07-28-2020, 03:52 PM   #13
Pete
Pete's Avatar
I wouldn't try it with a MIG welder. They are a constant voltage type power supply.
It can and does work fine with a regular stick welder. They are a constant current type power supply. All you need is a way to positively connect to the rivet. The connection needs to be able to pass the required current WITHOUT arcing.
Old 07-28-2020, 04:01 PM   #14
G.M.
You have to be careful shorting out the contact tip of
a MIG welder. When shorted the amps go way up. How
high depends on the out put range the machine is set
at. This can burn out the transformer and possibly the
diodes. You can use as a power supply for chrome
platting, starting a car and other applications where a
DC power supply is required. G.M.
I made MIG welders in the 60's. I made the first ones
for body shops, it was called "Fender Mender" They were
sold by welding supply companies and didn't really catch
on until body and paint supplies started selling them. I
sold the company in 1980. They still make welders for
Snap-On. G.M.
www.fordcollector.com
Old 07-28-2020, 05:15 PM   #15
woodiewagon46
Pete, I replaced the front crossmember and all four running board brackets on my '29 coupe frame with everything purchased from Big Flats Rivet Co. With the proper tools and some oxyacetylene heat, it's really not a big deal. Your trying to reinvent the wheel using a MIG welder.
woodiewagon46 is offline   Reply With Quote
Old 07-28-2020, 05:57 PM   #16
deuce_roadster
Pete, did you read the instructions on the Big Flats website? The proper size rivet for the correct size hole is important.
Old 07-28-2020, 06:42 PM   #17
Pete
Pete's Avatar
No, didn't read that but I have done steel riveting and am aware of the requirements.
The biggest job I was in on was riveting in a new fire box in a steam locomotive.
The rivets were 1 inch in diameter. It took 4 people to handle it.
Old 07-28-2020, 08:37 PM   #18
PeteVS
PeteVS's Avatar
That's post #22! Thanks! Looks like I have to see if a friend will loan me his stick welder.
Old 07-28-2020, 09:03 PM   #19
Tinker
Tinker's Avatar
Thinking a tig welder would be better for rivets. But I guess tig is closer to a oxyacetylene torch.
Old 07-28-2020, 10:56 PM   #20
Tim Ayers
What about one of the cheap spot welders from Harbor Freight?
