01-25-2021, 12:16 PM | #1 |
1935 Ford ignition switch
I took my ignition switch out to replace brush inside. Pieces fell out on floorboard and I can’t figure out how to put it back together. 😂 Anybody have a detailed pic of how the pieces go back together?! Help wanted!🤷🏿www.jalopyjournal.net♂️ Thanks
01-25-2021, 02:41 PM | #2 |
Re: 1935 Ford ignition switch
The flat piece of metal goes on first with the small bent tab inserted into the rear slot of the ignition switch on/off lever. then the cup with the movable switch contact and finally the cover.
01-25-2021, 03:03 PM | #3 |
It's tricky to reassemble. The ignition switch contact brush pivots on the shoulder of the small hole in the bottom ignition switch housing. Now, place the terminal plate over the top of the housing. You'll have to find a way to hold the assembly together. I used a very thin ty-rap/zip-tie. After attaching the assembly to the column drop with the two screws, I cut and removed the ty-rap. See this thread > https://www.fordbarn.com/forum/showt...tch+reassembly
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 01-25-2021 at 08:41 PM. |
01-25-2021, 04:42 PM | #4 |
Here's an exploded view of the assembly done by Gary Tosel a while back.
01-25-2021, 09:45 PM | #5 |
Thats a great drawing. Printed for future reference.
01-26-2021, 05:24 AM | #6 |
Thanks Don for adding this very detailed Drawing to this Thread. It is very helpful. |
01-26-2021, 01:03 PM | #7 |
Somewhat off topic, but that helpful diagram that Don posted is slightly different for '35-'36 phaetons and roadsters. The bolts attaching the housing to the dash insert from the bottom, not from the top and the holes in the housing are bored out to eliminate the threads. The part on the inside of the dash (18) came in two forms, the first being a hefty steel block with raised ends to clear the bottom of the speedometer and the second a steel stamping folded over to be of sufficient thickness to be threaded for the attaching bolts like the steel block. You can always tell a housing that was originally used on a phaeton or roadster as it lacks threads in the two attaching holes at the top.
