Old 01-25-2021, 11:12 AM   #1
GregJac
Default Leakless water pump weep hole
I installed a "leakless" water pump on my '30 Coupe. It has less than two hours running time on it and leaks from a weep hole located on the mounting flange.
Anyone else experience this?
GregJac is offline   Reply With Quote
Old 01-26-2021, 02:33 PM   #2
rocket1
Default Re: Leakless water pump weep hole
CALL THE SUPPLIER don't mess with it.
rocket1 is offline   Reply With Quote
Old 01-26-2021, 02:50 PM   #3
jak
if I remember correctly one of the water pump mounting stud holes in the head is drilled all the way through the casting. Is water weeping around that stud? If so I've
seen people use RTV or gasket sealer on the threads to help seal them up.
jak is online now   Reply With Quote
Old 01-26-2021, 03:01 PM   #4
McMimmcs
McMimmcs's Avatar
Talk to the supplier. Don’t mess with it.
Old 01-26-2021, 10:05 PM   #5
GregJac
I bought the pump from mac's about a year ago. I tried to call them but their customer service leaves a lot to be desired...
I was curious enough to press it apart. The bearings are all sealed and it has a mechanical seal that is spring loaded. I believe the problem is the seal allows coolant to to get around the seal flange and drain from the weep hole.
I'll end up eating this and buying a quality part.
Thanks for the help.
Old 01-26-2021, 10:22 PM   #6
McMimmcs
McMimmcs's Avatar
Obviously the mistake was trying to do your own repairs. One more of life’s little lessons.
Old 01-26-2021, 11:11 PM   #7
J Franklin
J Franklin's Avatar
You should be able to repair that pump now that you see what it needs.
Old 01-27-2021, 03:03 AM   #8
updraught
updraught's Avatar
It must be one of these with sealed bearings
https://www.macsautoparts.com/1928-2...-845453-1.html
Must have a weep hole to protect the sealed bearings.
"The front and rear grease fittings are for show only. The bearings are the sealed type that will provide many years and miles of trouble-free driving. The seals are made from material far superior to the original as well."
updraught is offline   Reply With Quote
Old 01-27-2021, 05:35 AM   #9
Synchro909
Synchro909's Avatar
Would some sealing compound like silicone or Permatex stop water getting around the flange? The spring loaded seal you refer to is probably a ceramic seal and should be good for your lifetime. I did say "should" but it is Mac's
Old 01-27-2021, 06:20 PM   #10
rocket1
A lot of pumps are a carbon and ceramic seal set up which are long lasting IE pool filter,dishwashers.
Old 01-27-2021, 08:30 PM   #11
Synchro909
Synchro909's Avatar
It doesn't take a lot of ability to graft one of those seals into a Model A water pump - can't be - I've done it.
Old 01-27-2021, 08:52 PM   #12
Flathead
Flathead's Avatar
Picked one up at a flea market, whoever did it did a nice job.
Flathead is offline   Reply With Quote
Old 02-11-2021, 01:47 AM   #13
GregJac
I recently bought a new water pump from Snyder's. I compared it to the one purchased from mac's. The quality of the Snyder's pump was far superior to the Chinese pump.
Installed on car and no problems at all. I have another (expensive) paper weight and conversation piece.
Thanks again for all of the help.
Old 02-11-2021, 04:56 AM   #14
updraught
updraught's Avatar
You can leave a review, it helps those of us in the sticks
https://www.macsautoparts.com/1928-2...ails_tab-title
Old 02-11-2021, 05:47 AM   #15
GregJac
updraught, I need to itemize the bad parts and go back and do a group review...
I found out about them at a high price. I found a seasoned restorer and he put me onto Snyder's Antique auto parts. I have had great service and good quality parts. They are online.
