Old 01-21-2021, 02:12 AM   #1
Fortunateson
Default Calling Ol'Ron, calling Ol'Ron...
As the title says. Tried his personal email but message was rejected. Posted a Barm PM and no replies yet.
Fortunateson is offline   Reply With Quote
Old 01-21-2021, 05:44 AM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: Calling Ol'Ron, calling Ol'Ron...
I just checked my PM, and your RIGHT, I didn't answer you. However, I remember answering you, I probably forgot to push the right button. At 87 I forget allot of things. SSsssOOoooo??? Why .030?? Why 3 97's? Charley ny for dist great. What cam, any?
Whe building a street engine you low end need torque. The only thing that gives you this is compression and displacement. .060 or .125 would cost almost the same as .030" and give you more displacement and compression. 3 97 for a small engine would would be allot of trouble for local driving even with progressive linkage. However, by blocking off the center card ( leave the carb on) you could have a dual system. For street use install 2" risers under them. Sorry about that
Gramps
Now everybody else will offer their opinions as well.
Ol' Ron is online now   Reply With Quote
Old 01-21-2021, 09:03 AM   #3
mfirth
My opinion is to listen to OL'Ron .....
mfirth is offline   Reply With Quote
Old 01-21-2021, 10:02 AM   #4
Kube
Kube's Avatar
I could not agree with you more. Listen to the man!
Nothing like advice from a guy that has "been there and done that" more times than mere mortals such as myself can imagine.
Old 01-21-2021, 10:19 AM   #5
mfirth
Kube, i've read enough of your stuff here & on V8 Times to know you rank right up there too. My last 8BA was inspired a lot by Barners with experience.
Old 01-21-2021, 10:25 AM   #6
Kube
Kube's Avatar
Thanks for the kind words. While I believe I do "okay" I can't help but have admiration for "ol Ron. They guy KNOWS his stuff. I read all of his posts and have learned quite a bit.
Old 01-21-2021, 11:35 AM   #7
Ol' Ron
Ol' Ron's Avatar
OK, Buy the book!!!
Gramps
Old 01-21-2021, 11:45 AM   #8
1931flathead
Ron is the man I learn a lot from him he probably forgot more then I will ever lnow
1931flathead is offline   Reply With Quote
Old 01-21-2021, 01:19 PM   #9
Fortunateson
Thanks. I'll get to CharlieNY for the distributor, I'll block off the centre carb, and I'll go see my machinist and discuss the .060 over versus the .030 over. I'll look into the 2" carb risers.
The cam is a local grind version of the Max1 so you advise using the .060 shims for the springs, correct?
Do you know how much the compression rises with my original Eddie Meyer heads?
One last thing, you did answer me but you had a couple of questions and you suggested I use your personal email. I tried but it bounced back so that is why I started this thread.
Thanks for all the help, I REALLY appreciate it!
Old 01-21-2021, 01:44 PM   #10
McMimmcs
McMimmcs's Avatar
The man has built a reputation of being one of the best ! Congratulations
Old 01-21-2021, 01:56 PM   #11
tubman
tubman's Avatar
Ask your machinist why he wants to stick with the small overbore. Has he documented thin cylinder walls or a core shift with sonic testing, or is he just applying his experience with modern thin wall castings? Like Ron says, "Whe[n] building a street engine you [want] low end need torque. The only thing that gives you this is compression and displacement. .060 or .125 would cost almost the same as .030" and give you more displacement and compression". This has been my experience as well. Back in the day, a lot of guys took these engines to 3 3/8"+.030 or even 3 7/16", so an 1/8" (.125) still leaves you with plenty of meat for the future unless a specific problem exists. You should really talk to your machinist because you should know about any such problems with the block.
Old 01-21-2021, 06:36 PM   #12
Ol' Ron
Ol' Ron's Avatar
I reality, I don't kow much about the early cars, other than the trans and reak axles can't stand up to much abuse. In the early street days the 404 Ols engine was king, and cheap, it did't take long before it hot bigger, 324/372?? In 55 the SBC came out and a 283/ Dum cam for $18,75 made more power than 2 flatheads. And then there was the Hemi. Stock cars and racing brought back the flathead. At this point you start by coping what others do, but this way you don't get any better, so you begin to experiment and after 7/8 years we set a track record. You can't believe how proud we were. unfortunately, they??? sabotaged the radiator with small pieces of shop rags . well at least we got their attention.
Old 01-21-2021, 07:00 PM   #13
39portlander
39portlander's Avatar
and try that Flathead chili recipe in the back of Nostalgia, it's MMM...good
39portlander is offline   Reply With Quote
Old 01-21-2021, 07:49 PM   #14
Zeke3
Zeke3's Avatar
Okay, it has been awhile since I have read Ol Ron's book, so I am going to have to get it out and re-read it. And, check out that chili recipe.
Zeke3 is offline   Reply With Quote
Old 01-22-2021, 12:26 AM   #15
Kilohertz
Kilohertz's Avatar
Okay for us newbies, could someone please point me to 'ol Ron's book? I would love to read it as I am just starting to think about a full rebuild...maybe.
Thanks
1949 Ford F-47 with a '51 8BA Flatty, GM TBI fuel injection system, and a grey shop cat, Spot.
Kilohertz is offline   Reply With Quote
Old 01-22-2021, 06:15 AM   #16
39portlander
Thanks
While your in the book mode, Flathead Facts by John Lawson should also be on your list. JWL also posts on Fordbarn.
Learn what works, Why it works and How it works. Keep the flame burning
Old 01-22-2021, 07:13 AM   #17
Ol' Ron
Ol' Ron's Avatar
You can get either book from Max VP, we need the money.
Gramps
Old 01-22-2021, 07:22 AM   #18
chap52
chap52's Avatar
To all those who share their lifetime of knowledge with us...THANK YOU good and faithful servants... Chap
Old 01-22-2021, 10:23 AM   #19
G.M.
You don't just stick .060 shims under warn weak
springs. There is a spring test machine that shows
the spring pressure at a set height. They should
all be close to the same pressure. G.M.
www.fordcollector.com
Old 01-22-2021, 10:33 AM   #20
HambBurglar
HambBurglar's Avatar
Funny! I got your book in the mail today from Van Pelt’s. Really looking forward to reading it thoroughly. Joe
HambBurglar is offline   Reply With Quote
