Old 04-09-2020, 06:18 PM   #20
Pete pa
Default Re: Zephyr overdrive into 1940 Ford?
The 40 coupe I'm building now I used the 48 Lincoln v12 and overdrive, and had to cut the x member out to mount the transmission in the frame, the shift solenoid sticks way out from the trans that gave me some problems to work around. If you are putting it behind a v8 it would require less cutting. There are pictures of the car in my album on the HAMB if you want to see what I had to cut out. Look at Two Couped up album.
Pete pa is offline   Reply With Quote
