Old 05-19-2012, 11:48 AM   #1
JT FORD
JT FORD's Avatar
Default 8BA motor with sticky valve
Valve is sticking on my '49. It runs good on the road, but as soon as I stop at a stop sign or light at slow idle it stumbles and will stop. I have to
pull the choke out to keep it running. I tried some Deep Creep, spraying
it down the carb with the engine running about 1/2 throttle, helped for a
short time, but its back. Any ideas?, Maybe MMO in the oil?? I run MMO
in the gasoline now.......
JT FORD is offline   Reply With Quote
Old 05-19-2012, 12:22 PM   #2
trainguy
trainguy's Avatar
Default Re: 8BA motor with sticky valve
What makes you think it is a stuck valve? Souns more like a carb problem
trainguy is offline   Reply With Quote
Old 05-19-2012, 01:03 PM   #3
jdl
jdl's Avatar
Send a message via ICQ to jdl
sounds more like a fuel related problem.
Carb adjustment, or fuel pump flex line or fuel pump glass bowl gasket.
jdl is offline   Reply With Quote
Thread Tools
Display Modes
