10-04-2021, 01:56 PM | #1 |
Master cylinder to brake line adapter
I have a Early 70s master cylinder that I need adapters for 1/4 inch inverted flare brake lines.
Anyone have the part numbers handy that i can go off of?
Tim Downtown, Ca |
10-04-2021, 03:19 PM | #2 |
Re: Master cylinder to brake line adapter
What is the existing thread in your 70's master cylinder?
10-04-2021, 03:47 PM | #3 |
I think it’s a 1/2–20 & female rev flare 1/4” line
Tim Downtown, Ca |
10-04-2021, 04:11 PM | #4 |
Did you try your local parts store? Most have the correct adapters.
10-04-2021, 04:21 PM | #5 |
Yup, nada.
I looking for someone with direct knowledge of the part #s. Found one. Thx....
Tim Downtown, Ca Last edited by CA Victoria; 10-04-2021 at 04:34 PM. |
10-04-2021, 04:40 PM | #6 | |
Check with a dealer for which ever brand the master is used on. Doubt if you will get a part # here.
10-04-2021, 05:19 PM | #7 | |
https://agscompany.com/product/steel...2-20-inverted/ |
10-05-2021, 09:12 AM | #8 |
In case someone else is looking, the correct call out is:
1/2-20 x3/8-24 inverted flare (1/4 tube) brake line adapter. There are two different sizes the larger adapter is 9/16-18 x 3/8-24 inverted flare
Tim Downtown, Ca |
10-05-2021, 09:30 AM | #9 |
So where did you find them?
10-05-2021, 10:42 AM | #10 |
You stated in your first post you want 1/4" pipes. The fittings you have listed seem to be quoting a 3/8-24 thread which is for a 3/16" pipe.
Dual masters I have had have had a 1/12" and a 9/16" thread fitting. Look up the fittings below. I found them at Rockauto. |
10-05-2021, 11:13 AM | #11 |
Something to watch out for when using those adapters; couple times I found that the adapter contacted the body of the master cylinder instead of seating on the brass insert. Faced off the body a bit so it seated.
I usually use the "oversize" tube nuts instead of the adapters when I can. |
