Old 09-05-2021, 11:08 PM   #1
jtminor
Default 49 F1 Brake issue
Truck pulls sharply to the left when applying the brakes, assuming the right brake is not functioning. I have no experience with brake repair, where should I begin this investigation. Any help will be appreciated
Jim - WI
jtminor is offline   Reply With Quote
Old 09-06-2021, 12:47 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: 49 F1 Brake issue
You'll have to pull the wheel & drum & have a look in there for signs of wheel cylinder leakage. The old type brakes aren't self adjusting types. There may be wear or lining contamination problems.
Old 09-06-2021, 10:15 AM   #3
5851a
https://i.ebayimg.com/images/g/QtwAA...RKJ/s-l500.jpg You will find one of these very handy to have.
5851a is offline   Reply With Quote
Old 09-06-2021, 12:43 PM   #4
jtminor
here's what I'm looking at.....
Old 09-06-2021, 12:45 PM   #5
1931 flamingo
1931 flamingo's Avatar
Check the hoses going to the front wheels.
Paul in CT
Old 09-06-2021, 12:56 PM   #6
jtminor
Thanks Paul , what will I be looking for on the hoses
Cracks, leaks..
Jim
Old 09-06-2021, 01:03 PM   #7
1948F-1Pickup
1948F-1Pickup's Avatar
Old age. They can collapse internally, thereby “necking down”on ID and causing a restriction. I once chased this issue on a brand new hose that was improperly manufactured also.
1948F-1Pickup is offline   Reply With Quote
Old 09-06-2021, 01:05 PM   #8
Zeke3
Zeke3's Avatar
Check the keft front brake for leaks if the car is pulling to the left.
Zeke3 is offline   Reply With Quote
Old 09-06-2021, 01:21 PM   #9
Mart
Mart's Avatar
Buy some new cylinders and hoses and fit them. They're cheap. If the shoes are good re-use them.
You need to tackle this job because you need to build up the familiarity with the old stuff if you want to drive with confidence.
Inspect both sides and only dismantle one side. Then you have the complete side as a pattern if you can't see how it goes back together.
To be honest, that is one of the simplest setups there is so would be a good one to have a go at if it is your first time.
Mart.
Old 09-06-2021, 01:52 PM   #10
Bob C
Looks like the brake shoes are backwards, short shoe should be on the front.
Bob C is online now   Reply With Quote
Old 09-06-2021, 01:53 PM   #11
jtminor
Any tips on removing the springs.......
Old 09-06-2021, 01:55 PM   #12
jtminor
Just bought the truck, last owner had it for 48 years... I don't know when the brakes for looked at.....
Old 09-06-2021, 01:58 PM   #13
jtminor
Floor jack is in the front of the truck in the picture
Old 09-06-2021, 02:04 PM   #14
VeryTangled
VeryTangled's Avatar
Brake Pliers : How to use both sides
https://www.youtube.com/watch?v=ngPODfdifxc
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 09-06-2021, 02:04 PM   #15
Mart
Mart's Avatar
JT, you can get a simple set of tools for the brakes, there is a doodad that winds the springs off and helps you slip them on.
These pliers have the ends like the tools you need. Go to your local auto parts place and ask for old type brake tools.
The round end takes the springs off and the shaped end puts them on.
Old 09-06-2021, 03:15 PM   #16
richard crow
if you don,t know any thing about brakes bring it to some one that doe.s. that,s a bendix brake any repair shop is fermelia with them. brakes are nothing to fool with
richard crow is offline   Reply With Quote
Old 09-06-2021, 04:36 PM   #17
JSeery
JSeery's Avatar
Yes, on Bendix brakes, short shoe toward the front.
Old 09-06-2021, 07:57 PM   #18
jtminor
Problem ... left front drum won't come off, bigger problems?
Old 09-06-2021, 08:46 PM   #19
tubman
tubman's Avatar
Sounds like a wear problem. Have you backed the adjusters on that wheel all the way off?
Old 09-06-2021, 10:00 PM   #20
jtminor
No I have not, will try in the morning.....
Thanks
