09-01-2021, 08:55 AM | #1 |
Rear axle shims
Just discovered a shim on the left axle, so there is one on each side. Since the hub does not rotate on the axle, how can there be enough hub to axle abrasion to cause wear?
09-01-2021, 10:12 AM | #2 |
Re: Rear axle shims
Caused by the vehicle being driven w/out the nut being properly tightened enough.
09-01-2021, 10:45 AM | #3 |
Re: Rear axle shims
09-01-2021, 10:46 AM | #4 |
Re: Rear axle shims
You can try removing the shim and reinstalling the hub to see if the brake drum rubs the backing plate most likely it does rub and that is why the shim was installed.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
09-01-2021, 08:16 PM | #5 |
Re: Rear axle shims
The axle nuts have to be tightened once a year or more depending on how much you drive the car
09-02-2021, 08:09 AM | #6 |
Re: Rear axle shims
Bob Bidonde Last edited by Bob Bidonde; 09-02-2021 at 08:18 AM. |
09-02-2021, 08:29 AM | #7 |
Re: Rear axle shims
Good explanation, but can't help noting conflicting info. Others have declared that the torque is transmitted from the tight fit of the hub to the axle, and NOT the key. Also, you recommend torqueing nut to 50 lbs, whereas almost all others recommend 100 lbs. New hub is on order.
09-02-2021, 08:43 AM | #8 |
Re: Rear axle shims
Take the key out of the right rear axle hub and attempt to drive the car on the friction fit of the taper alone. Let me know how far the car goes. As for the torque value, the higher the torque, the higher hoop stress in the hub goes. At 100 lbs-ft of torque on the nut, I think the hub is yielding. I doubt that the factory assembly-line worker torque the nut to 100 lbs-ft. That's a 100 lb force on a 1-foot long wrench!
Bob Bidonde |
09-02-2021, 10:57 AM | #9 |
Re: Rear axle shims
Without the key, or with a broken key the car will stop moving. However, the key being there is not the only reason the car moves. The key along with the torque on axel tapper is how it was designed to work. A loose hub will ware both the axel end and eventually break the key. Causing the axel to spin within the hub.
A properly torqued axel without a key will move the car. How long? You need both for it to work properly. 100 foot pounds is the right figure. Not my first rodeo with this problem. Enjoy. |
09-02-2021, 12:01 PM | #10 |
Re: Rear axle shims
Not looking to provoke an argument here, just seeking best info and guidance from those who have lots more experience than me--that's everyone. I cannot possibly imagine working on a Model A w/o the participants on this forum. Thank you a thousand times, and I'll be back for more.
09-02-2021, 05:06 PM | #11 | |
Re: Rear axle shims
John
Welcome each day Last edited by john in illinois; 09-02-2021 at 05:18 PM. |
