Old 12-28-2019, 10:39 PM   #1
Willi_D
Willi_D's Avatar
Default 1941 Business coupe rear window garnish moulding
I have a 1941 Business coupe and need to replace the rear quarter window inner Garnish moulding..finding 2 types.. mine is the plain moulding one..( not tip out window ) Question is are the two inter changeable ? Can the type with hinge/pivot brackets be used or will need to be modified to fit? Any help appreciated Thanks
Willi_D is offline   Reply With Quote
Old 12-28-2019, 11:53 PM   #2
fordor41
fordor41's Avatar
Default Re: 1941 Business coupe rear window garnish moulding
I believe if you have tip out windows, the window, weatherstrip seal and inner garnish molding are a unit, at least that's how my '41 fordor was. The unit installed from the inside, pulling the outer seal out thru the opening. I don't even remember if it had screws to hold it in place, just the rubber. Not sure about a fixed window but doubt they are the same.
fordor41 is offline   Reply With Quote
Old 12-29-2019, 07:12 PM   #3
Willi_D
Willi_D's Avatar
Thanks for the clarification..
Old 12-29-2019, 11:30 PM   #4
50fordcoupeman
50fordcoupeman's Avatar
Willi............my book does not show a "business" coupe for 1941. It does show however deluxe and super deluxe coupes with and without jump seats. Ford made a total of 38,420 of these coupes. Is the book in error or did Ford not make an official 1941 "business" coupe? I do not know..........
50fordcoupeman is offline   Reply With Quote
Old 12-29-2019, 11:47 PM   #5
fordor41
fordor41's Avatar
everyone calls them B.C's but I don't think that was ford designation.
Old 12-30-2019, 12:30 AM   #6
50fordcoupeman
My Ford book actually calls them out as business coupes as compared to their other named cars such as custom deluxe coupes etc.
Old 12-30-2019, 02:31 PM   #7
1931 flamingo
1931 flamingo's Avatar
When did the long and/or short door coupes come out??
Paul in CT
Old 12-30-2019, 05:20 PM   #8
50fordcoupeman
Paul in CT
Hi Paul,
You got me on that one. I didnt know there was such a thing on the coupes and my book doesnt mention it. Sorry!
Old 12-30-2019, 05:32 PM   #9
TJ
TJ's Avatar
Long door and short door started in 1941 and ended in 1948.
Old 12-31-2019, 12:44 AM   #10
fordor41
fordor41's Avatar
Short doors are shared by the fordor and business coupe, long doors are shared by 5 pass. coupe and 2 door sedans. Also heard that the rear quarter windows are different between the fordor and coupes (height or lenght) although they appear to be identical. I may be wrong.
Old 12-31-2019, 01:13 PM   #11
Graeme / New Zealand
Graeme / New Zealand's Avatar
I've owned both coupes with flip out windows and fixed windows. Like 4door41 says the flip outs have a retainer built into them for the weather seal and holes for the pivots for the glass, also they have a clip on them for the window latch. The fixed type the glass fits inside a rubber extrusion and butts between the window opening and the garnish which unlike the flip out type does not have have the channel for the weather strip and the clip for the window lock. Coupe ones and fordor ones are different in height but are the same in length. On my current coupe one of the flipout windows had a rusted out channel in the bottom of the garnish. I could not find another sedan coupe one so I got a 4door one which was shorter in height and cut them both and grafted on the sedan bottom piece.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 01-02-2020, 10:50 PM   #12
G32
Guys;
40 Bus Coupe w opera seats was body code 67 and FMC called
Business Coupe. 1941 short door coupe with rear jump seats was also
body code 67 as 1940 BUS Cpe but called '5 window Coupe with auxilary
rear seating"-----so 41 is properly coded (and regarded) as a Business
Coupe -only 2 years for body code 67.
1941 -1954 had short cabin Club Coupes {also known as Sedan Coupe
in earlier years) body code 72-- models A B & C , The C model was a
back seat delete with rear metal cargo platform --called Business Coupe
Love these old FORDS!
Gene Tulsa
G32 is offline   Reply With Quote
Old 01-02-2020, 10:56 PM   #13
G32
Guys;
Don't forget the econo stripper model C the "Special"
Gene Tulsa
Ps;
V8 Album -- V8Club shows: 5 short door Coupes
41 Deluxe w/jump seats 11A-67A 2,683
41 Super Deluxe w/jump seats 11A-67B 6,575
41 Dlx Cpe 11A-77A 21,622
41 Supr Dlx Cpe 11A-77B 14,115
41 Special Coupe 11A-77C # not listed.
42 had 77A,77B,77C short door Coupes --no Code 67 (jump seat) Cpes
Gene Tulsa
Old 01-03-2020, 01:50 AM   #14
50fordcoupeman
Red face Re: 1941 Business coupe rear window garnish moulding
Originally Posted by G32 View Post
Guys;
Gene Tulsa
Ps;
Gene Tulsa
Yes I totally agree but they don't call out any of them being a "business coupe" like they on the others so is one of these a business coupe. I find this to be confusing.
Old 03-07-2020, 09:03 AM   #15
Willi_D
Willi_D's Avatar
Thanks for all your comments..Being a New guy to Fords.. Ill choose my terminology better next time..finally Ironed out the info on parts I needed...
Old 03-08-2020, 02:48 PM   #16
grumppyoldman
grumppyoldman's Avatar
I have some pics. of my 41 Business Coupe . I'll try and down load them. if I can. Al
grumppyoldman is offline   Reply With Quote
