Old 01-17-2019, 05:09 PM   #1
30 Closed Cab PU
Default Pickup upholtery install - nails/wood
This is a campanion post/thread about closed cap upholstery.
Pictures in the other tread shows the panels/cards are installed using small nails/brads.
Attached is a picture of my door, there is not wood.
Am I missing wood pieces
30 Closed Cab PU is offline   Reply With Quote
Old 01-17-2019, 05:14 PM   #2
30 Closed Cab PU
Default Re: Pickup upholtery install - nails/wood
Accidently postyed before finsished.
Attached is a picture of my door, I do not think there is wood behind the vertical strips with all the holes.
Possible I missing wood pieces that go in the door?
Old 01-17-2019, 05:14 PM   #3
30 Closed Cab PU
Am I missing wood pieces that go in the door?
Old 01-17-2019, 05:30 PM   #4
Stew Masche
Stew Masche's Avatar
If you check out Bratton's Antique Auto Parts, www.brattons.com
look under 'pick up cab parts'. Specifically, they list their part #32180
which is called the 'Pick Up Door Panel Nail'. It consists of a plastic insert that goes into the holes around the inside perimeter of the door, included is a large headed pebble grain finish 'nail' that goes through the trim panel, and into the plastic insert. Their catalog shows an insert and nail for $1.50 each, 24 needed per door. This'nail' has rings on the shank that hold into the plastic. I believe the originals were a similar affair, but all metal.
The trim pieces up the lock pillar and across the cab at the top of the door would have similar looking 'nails' but were actual nails.
I'm sure other vendors offer these as well, just happened to have my Brattons catalog handy.
Best Regards,
Stew Masche
Lake Mills, WI
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 01-17-2019, 05:47 PM   #5
30 Closed Cab PU
Hi Stew,
Thanks for the info, and got your other info you sent. It showed up on my smart phone email, but cant find it on my computer.
Will be sending you a PM.
Best Regards,
Stew Masche
Lake Mills, WI
