Old 04-18-2017, 06:56 PM   #1
JonC
Default steering wheel removal
I am starting on my 31 roadster project and was wondering if someone can point me in the right direction. How do you go about removing actually taking apart the column. I am afraid of breaking something so better to find the right way first. Is there a book that will guide me through it. Thanks
JonC is offline   Reply With Quote
Old 04-18-2017, 07:56 PM   #2
RRW
Send a message via Yahoo to RRW
Default Re: steering wheel removal
Les Andrew's handbook:
Model A Ford
Mechanics Handbook Vol. I
Page 1-317 & 1-318
RRW is offline   Reply With Quote
Old 04-18-2017, 08:00 PM   #3
Gunmetal blue2
Gunmetal blue2's Avatar
I found it helps if you take lots of pics as you take it apart. Just so you know you should have a 2 tooth steering column.
Gunmetal blue2 is offline   Reply With Quote
Old 04-18-2017, 08:04 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Loosen the shaft nut under the horn button, then pull rearward hard as you rock the steering wheel slightly from side to side. If it doesn't pop loose, then some have drilled and tapped 2 holes in the hub so they could use the common steering wheel puller. Don't hammer on the threads of the shaft.
Old 04-18-2017, 08:10 PM   #5
Joe K
Joe K's Avatar
The Service Bulletins actually do a pretty good job on the two-tooth columns. Centering the sector the big challenge best done on the bench.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 04-19-2017, 06:30 AM   #6
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
If the steering wheel won't come off, try this method. Short video.
https://www.youtube.com/watch?v=er3g...YNpnU0&index=7
Jacksonlll is offline   Reply With Quote
Old 04-19-2017, 06:48 AM   #7
Tom Wesenberg
That's a good idea and worth a try before drilling and tapping the hub.
It won't matter for this removal by rope, but if you use the bolts, the puller is pictured upside down.
Old 04-19-2017, 06:59 AM   #8
RonC
RonC's Avatar
There are special pullers for removing those wheels. You can buy one from the parts venders. Whatever you do don't bang on the shaft. The shaft threads are extremely delicate. Do not disassembly the assembly before you do a little research and are ready to rebuild it.
RonC is offline   Reply With Quote
Old 04-19-2017, 07:15 AM   #9
Big hammer
The steering shaft is not a shaft, it's a tube! Bill Williamson has a way to remove the wheel and always works, knees under the wheel, upward pressure, rock back and forth with your hands, it will pop off! Look out for your nose, yes it hit my nose
Old 04-19-2017, 08:10 AM   #10
Mitch//pa
Another option
Old 04-19-2017, 08:11 AM   #11
Mitch//pa
Thats why i put the nut back on a few threads before pulling...
On these old wheels be careful as they crack easy doing it this way.. grabbing the center of the wheel will help prevent that but you lose leverage
Old 04-19-2017, 08:19 AM   #12
JohnLaVoy
JohnLaVoy's Avatar
The wheel puller is the best way to do it.
JohnLaVoy is offline   Reply With Quote
Old 04-19-2017, 11:03 AM   #13
JonC
Thanks everyone. Mitch thanks for the picture, I can build that in the shop. My plan is to remove the box and column as a unit and disassemble on the bench. I will do some reading. Jon
Old 04-19-2017, 12:13 PM   #14
duke36
Tried everthing including the puller style pictured,with rocking motion, etc. The puller started to bend. Perhaps the newer ones are better. Since the old (30-31) wheel was to be replaced, a soft rubber mallet was used on the spokes close to the hub as possible along wih the slight rocking motion and very gentle taping to finally release the woodruff key. Unfortunately it appeared that someone had strong armed the nut to the shaft!.
duke36 is offline   Reply With Quote
Old 04-19-2017, 01:49 PM   #15
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Search for my "sure fire" removal method. Big Hammer has the general idea, BUT the knees aren't used.
An Old Dutchman taught me how to do it & I HAVEN'T ever used a puller since then.
Bill Slick
"THE ASSISTANT GURU OF STUFF"
Old 04-19-2017, 02:35 PM   #16
JonC
Thanks Bill
Old 04-19-2017, 03:05 PM   #17
harleynut
harleynut's Avatar
Might find this a little odd but I left the steering wheel on and removed the whole column with the steering box and all in one piece (less the pitman arm) thru the cab. I had the advantage of putting the top down on the Phaeton. Once out, I hung the steering column on my engine lift by the steering wheel with straps close to the center of the wheel. With the box about an inch above the floor, I gave it a little tap on the backed off nut and the steering wheel separated from the shaft nicely using the weight of the steering box. I had to take the whole assembly out anyhow to rebuild the box
harleynut is offline   Reply With Quote
Old 04-20-2017, 06:21 AM   #18
JonC
I am taking my whole unit out as well, thanks for the tip
Old 04-20-2017, 07:07 AM   #19
Chris H
Chris H's Avatar
I pulled the whole unit from my Tudor and put it in a vise. I bought one of the pullers from Macs, I think. It did not take long before it started to bend. I had to reinforce it by welding angle iron on it. (It ain't pretty.) I spent about two weeks of adding Kroil to the taper joint, tightening the puller, and smacking the puller bolt with a hammer. Each day, after work, I would go out and tighten the puller, give a few hammer blows, and add some Kroil. One day it just popped off! Thankfully, because I was running out of ideas. I wish I had thought of the method of drilling and tapping the hub, or the rope method.
I don't know if it was the right thing to do, but on reassembly, I applied a little anti-seize on the taper. That's been about 5 years ago, and haven't had any problems.
Chris H.
1930 Tudor
1964 MGB
1979 MGB
Ham call: N9WHH
Chris H is offline   Reply With Quote
Old 04-20-2017, 07:40 AM   #20
SeaSlugs
SeaSlugs's Avatar
Ive done it before on lawnmower steering shafts with grease - just a very light finger smear helps in the future. Just make sure both parts are clean before doing so and you keep the nut tight.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
