Old 11-24-2016, 01:22 PM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Backing plate lock washers?
I've assembled several backing plates in the past, but none of them had lock washers.
I just found a set of backing plate bolts which includes lock washers.
Has anyone ever seen these before?
Unfortunately, I only have one set.
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 11-24-2016, 01:29 PM   #2
Default Re: Backing plate lock washers?
They are thinner than a normal lock washer.
See picture.
Old 11-24-2016, 02:06 PM   #3
chuckstinn
chuckstinn's Avatar
Neil
My Oct '28 parts list mentions only 2 long and 2 short bolts with castle nuts and cotters, no lock washers.
chuckstinn is offline   Reply With Quote
Old 11-24-2016, 02:16 PM   #4
Jim/GA
Jim/GA's Avatar
Lock washers and castle nuts would be redundant. Henry pinched every penny. I doubt this double locking would fly with him.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 11-24-2016, 02:29 PM   #5
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
NOPE no lock washers at all,, Just the Cotter!
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 11-24-2016, 02:58 PM   #6
Bob C
The narrower ones are probably for socket head bolts.
Bob
Old 11-24-2016, 03:44 PM   #7
Thank you for good information.
However, I remember installing the bolts, castle nuts, and cotter pins before and having to bend the cotter pins to fit in the castle nut holes.
If a lock washer or even a solid washer was used before the nut, bending the cotter pin to fit in the castle nut holes would not be necessary.
Please comment.
