Old 09-11-2013, 08:35 AM   #1
JT FORD
JT FORD's Avatar
Default Stuck Starter Help
My brother-in-law just got a '49 v-8 tudor. Had the starter locked-up the other day They put the car in 3rd gear and rocked it and it got it out and it started. What can cause this? Does the starter need work or what???
Thanks in Advance
JT FORD is offline   Reply With Quote
Old 09-11-2013, 11:16 AM   #2
ford3
Default Re: Stuck Starter Help
either a bad bendix , a bent starter drive,or worn bushing at the starter shaft, you may have to pull the starter and check it for these problems,could even be a really worn ring gear on the flywheel
ford3 is offline   Reply With Quote
