08-16-2013, 09:25 AM | #1 |
Light Switch for l950 Ford
Light switch wouldn't work the tail lights. So I ordered a new one from a Ford supplier. After removing the old switch I installed the shaft/knob to
test the new one before installing it. Good thing I did, the headlight terminal was died! Then I tried to remove the shaft/knob and I had a hard time getting it out, I had to use waterpump pliers on the release button and pull very hard to get it out!!!! I returned it for credit, because the supplies said last one in stock and now cann't get anymore??? These China switches must be terrible. Anyone know of a good new one?????? JT |
08-16-2013, 09:32 AM | #2 |
Re: Light Switch for l950 Ford
Used one on Ebay for $25 BMN.Used U>S> made better that imports. Phil
08-16-2013, 09:33 AM | #3 |
Chris has re-opened the Shoebox store and forums.
Try him @www.shoebox-central.com |
08-16-2013, 10:41 AM | #4 |
I checked with Chris and he replied that he has a worked over original for $40.00. Its probably better than a China new one....
08-16-2013, 10:55 AM | #5 |
Watch e-Bay and also check with Stacy Brown in Texas. He has a lot of NOS parts. Also check with the Early Ford Store in San Dimas, Ca. Lots of NOS parts there also.
08-16-2013, 11:03 AM | #6 |
08-16-2013, 08:19 PM | #7 |
Headlight switch is the same 1950 to 1954 Ford & Mercury
Try Stacy Brown for a NOS. Antique auto supply, Arlington, Tx. 1-817-275-2381 http://www.antiqueautosupply.com/ |
08-17-2013, 09:26 AM | #8 |
Stacey at Arlington has 4 in stock right now, according to my parts locatoir.
Barry 50 F-1 |
08-17-2013, 09:46 AM | #9 |
7RA 11654 is for the 1949.FAA 11654 A is the Ford number for 1950-54.
08-17-2013, 09:53 AM | #10 |
Motorcraft number was sw296.If Stacy doesn't have it you might call Green Sales in Ohio 800-543-4959.They show 50 in stock.They have always been good about telling me if something was repop or NOS.
08-17-2013, 06:51 PM | #11 |
Stacey shows 4 of FAA 11654-A also. Green shows 52, so you know they're chinese.
Barry 50 F-1 |
