12-28-2019, 10:39 PM | #1 |
1941 Business coupe rear window garnish moulding
I have a 1941 Business coupe and need to replace the rear quarter window inner Garnish moulding..finding 2 types.. mine is the plain moulding one..( not tip out window ) Question is are the two inter changeable ? Can the type with hinge/pivot brackets be used or will need to be modified to fit? Any help appreciated Thanks
12-28-2019, 11:53 PM | #2 |
Re: 1941 Business coupe rear window garnish moulding
I believe if you have tip out windows, the window, weatherstrip seal and inner garnish molding are a unit, at least that's how my '41 fordor was. The unit installed from the inside, pulling the outer seal out thru the opening. I don't even remember if it had screws to hold it in place, just the rubber. Not sure about a fixed window but doubt they are the same.
12-29-2019, 07:12 PM | #3 |
Thanks for the clarification..
12-29-2019, 11:30 PM | #4 | |
12-29-2019, 11:47 PM | #5 |
everyone calls them B.C's but I don't think that was ford designation.
12-30-2019, 12:30 AM | #6 |
12-30-2019, 02:31 PM | #7 |
When did the long and/or short door coupes come out??
Paul in CT |
12-30-2019, 05:20 PM | #8 |
12-30-2019, 05:32 PM | #9 |
Long door and short door started in 1941 and ended in 1948.
12-31-2019, 12:44 AM | #10 |
Short doors are shared by the fordor and business coupe, long doors are shared by 5 pass. coupe and 2 door sedans. Also heard that the rear quarter windows are different between the fordor and coupes (height or lenght) although they appear to be identical. I may be wrong.
12-31-2019, 01:13 PM | #11 |
I've owned both coupes with flip out windows and fixed windows. Like 4door41 says the flip outs have a retainer built into them for the weather seal and holes for the pivots for the glass, also they have a clip on them for the window latch. The fixed type the glass fits inside a rubber extrusion and butts between the window opening and the garnish which unlike the flip out type does not have have the channel for the weather strip and the clip for the window lock. Coupe ones and fordor ones are different in height but are the same in length. On my current coupe one of the flipout windows had a rusted out channel in the bottom of the garnish. I could not find another sedan coupe one so I got a 4door one which was shorter in height and cut them both and grafted on the sedan bottom piece.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
01-02-2020, 10:50 PM | #12 | |
Guys; 40 Bus Coupe w opera seats was body code 67 and FMC called Business Coupe. 1941 short door coupe with rear jump seats was also body code 67 as 1940 BUS Cpe but called '5 window Coupe with auxilary rear seating"-----so 41 is properly coded (and regarded) as a Business Coupe -only 2 years for body code 67. 1941 -1954 had short cabin Club Coupes {also known as Sedan Coupe in earlier years) body code 72-- models A B & C , The C model was a back seat delete with rear metal cargo platform --called Business Coupe Love these old FORDS! Gene Tulsa Last edited by G32; 01-02-2020 at 11:37 PM. Reason: spelling ?? |
01-02-2020, 10:56 PM | #13 | |
Don't forget the econo stripper model C the "Special" Gene Tulsa Ps; V8 Album -- V8Club shows: 5 short door Coupes 41 Deluxe w/jump seats 11A-67A 2,683 41 Super Deluxe w/jump seats 11A-67B 6,575 41 Dlx Cpe 11A-77A 21,622 41 Supr Dlx Cpe 11A-77B 14,115 41 Special Coupe 11A-77C # not listed. 42 had 77A,77B,77C short door Coupes --no Code 67 (jump seat) Cpes Gene Tulsa Last edited by G32; 01-03-2020 at 12:13 AM. |
01-03-2020, 01:50 AM | #14 | |
03-07-2020, 09:03 AM | #15 |
Thanks for all your comments..Being a New guy to Fords.. Ill choose my terminology better next time..finally Ironed out the info on parts I needed...
03-08-2020, 02:48 PM | #16 |
I have some pics. of my 41 Business Coupe . I'll try and down load them. if I can. Al
