Old 07-20-2017, 09:47 PM   #1
Strodder
Strodder's Avatar
Default 16 spline Slip yoke
I converted a 40 3 speed to an open driveshaft. Now I need a 16 spline slip yoke. I know it's been asked before, but never found a good answer. What years should I look for? Or where can I buy a new one. Some of the places I looked on the net were confusing. Does anybody have a link I can go to, even if it's E-Bay.
Thanks in advance,
Dennis
Strodder is offline   Reply With Quote
Old 07-20-2017, 10:45 PM   #2
Newc
Newc's Avatar
Default Re: 16 spline Slip yoke
H;i the original yokes are usually with the driveshafts,use a pressed in u joint. I have heard of a GM yoke that will work. the yoke is fixed by a bolt into the output shaft right? Others will jump in on this post. Newc
Old 07-20-2017, 11:55 PM   #3
Art Newland
Art Newland's Avatar
I just picked up a NOS yoke from "barnfind08", contact him and see if he has another.
Art Newland is offline   Reply With Quote
Old 07-21-2017, 12:38 AM   #4
34fivewindow
34fivewindow's Avatar
1955 to 61 GM cast iron powerglide yoke.
34fivewindow is offline   Reply With Quote
Old 07-21-2017, 09:07 AM   #5
V Clark
55 chev. power glide yoke will work .. A little longer but can be trimmed . I think the original is about an 1" shorter. I can check my pile and look when I get out in the shop .. Not too hard to locate for you I would think. Van
V Clark is offline   Reply With Quote
Old 07-21-2017, 09:50 AM   #6
Strodder
Strodder's Avatar
Thanks. Can you post a picture of it when you find it?
Old 07-21-2017, 11:19 AM   #7
rotorwrench
rotorwrench's Avatar
The 21C-4841 was the first knuckle & plug (or slip yoke) for the open drive commercials and it was used from 1942 to 1952. It should be relatively common, especially when folks are swapping out the Dana Spicer stuff for something else.
Old 07-21-2017, 12:17 PM   #8
skidmarks
skidmarks's Avatar
I got one if your still looking. $45 shipped to your door. Its out of a 50 ford F1
skidmarks is offline   Reply With Quote
Old 06-12-2019, 12:37 PM   #9
alanp561
alanp561's Avatar
Do you still have your 50 F1 16 spline slip yoke?
alanp561 is offline   Reply With Quote
Old 06-13-2019, 09:26 AM   #10
Strodder
Strodder's Avatar
Sorry, no
Old 06-14-2019, 03:21 AM   #11
tub1
tub1's Avatar
I think manual customline one fits
tub1 is offline   Reply With Quote
Old 06-14-2019, 06:03 AM   #12
Mac VP
Mac VP's Avatar
We stock them.....it’s made to fit the regular passenger car transmission but will fit the short pickup trans like you have by trimming it down about an inch and a half. They have the same knuckle set up as the original Ford pickup driveshaft did.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
