08-13-2020, 09:21 AM | #1 |
What else fits the horns???
SO
on my 39 Mercury I kept getting a "rattling" "vibrating" noise from under the front of the car like the engines tins were loose OR the splash shields under the fenders were loose. I had the car up on the lift on a couple of occassions and poked around and could NOT find anything!!! The other day it was real bad and discovered its my "lower" horn that is very loose and rattling around SO am I missing what appears to be maybe some rubber grommets as well as maybe another clamp???? |
08-13-2020, 09:29 AM | #2 |
Re: What else fits the horns???
You need horn grommets. B-14605
https://www.bobdrake.com/SearchForm....0&searchtype=0 |
08-13-2020, 09:30 AM | #3 |
1939/40 horn trumpet grommets are available from several of the reproduction parts sources
08-13-2020, 09:33 AM | #4 |
I figured they were missing BUT wondered IF there was a second "clamp" OR "IF" maybe mine is too close to the horn end and "needs" to be moved out more to the trumpet end as well????
Thank you!!! |
08-16-2020, 01:25 AM | #5 |
Got the same horns in my car but a previous owner has welded then to the bracket. As said the grommets are easily obtained . I got some for my last v8 but the things still moved around so I got a big cable tie and secured them with that....a tempary fix that ended up being permanent.
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
08-16-2020, 07:15 AM | #6 |
08-16-2020, 11:03 AM | #7 | |
The bracket towards the front utilizes that wire "clip". Once the grommets are placed, that wire goes around them.
08-16-2020, 12:29 PM | #8 |
"Kube" Thanks for that info. Learned something new.
08-16-2020, 01:56 PM | #9 |
So the wire clip needs to be moved more toward the “TRUMPET” end??
08-16-2020, 02:06 PM | #10 |
correct
08-16-2020, 02:39 PM | #11 |
If you have the green parts book there is a good picture on page 558.
