08-12-2020, 08:17 PM | #1 |
repo 34 horns
small problem.
repro 34 horns will not work with original wireing. new ( vintique I think ) are nice NOT PERFECT . 12 volt they have a + ternimal and a - one --- since the original horns work with + to horn and horn button makes ground and the horn honks. I think the only way to make work is with a relay. anyone sharp enough to make me a wireing diagram? thanks for any helpe Nick |
08-12-2020, 08:20 PM | #2 |
Re: repo 34 horns
Nick,
They are not Vintique.. But regardless, just want to make sure.. You bought the 6V version correct? They make a 12V as well. They can and will operate without a relay, but do to the amperage dram compared to a original, they recommend a relay. |
08-12-2020, 09:03 PM | #3 |
Re: repo 34 horns
Funny that you asked, I just went through this issue and resolved it today on my friends 33 Ute. Our issue was that the horns grounded out once they were mounted on the brackets, so every time you connected power to the car, the horns would blow. To use the original wiring we either had to isolate the horns from ground or use a set of relays to make them work properly.
We used two 4 pin relays and hid them in the horn caps. If you are running an original wiring wiring harness and don’t want to splice into the horn button wire you can try this. 1. Connect the 12V power to pin 30 and pin 86. (Yellow wire). 2. Run your wire from the horn button to pin 85. (Blue wire). 3. Run a wire from pin 87 to the positive side of the horn. (Red wire). 4. You do not need to connect the negative terminal on the horn if the horn has a good ground connection with the mounting bracket. If does not connect the negative horn terminal to a good ground source. Relays come in many shapes and sizes, so we found this one at the auto parts store. Then we used some electrical tape to insulate the terminals so it would not short out against the horn cap. I am not an electrical expert, so this may not be the most elegant solution. Hope this helps, good luck! Sent from my iPad using Tapatalk |
08-12-2020, 09:17 PM | #4 |
Re: repo 34 horns
Or
08-12-2020, 09:24 PM | #5 |
repo 34 horns
These diagrams are correct if you have power running through your horn button. Sent from my iPad using Tapatalk Last edited by Bursonaw; 08-12-2020 at 09:32 PM. |
08-12-2020, 09:24 PM | #6 |
Re: repo 34 horns
08-12-2020, 09:27 PM | #7 |
Re: repo 34 horns
08-13-2020, 08:45 AM | #8 |
Re: repo 34 horns
Thank all of you------- just what i needed
ford barn to the rescue again |
