Old 08-12-2020, 02:24 PM   #1
3twinridges
3twinridges's Avatar
Default F1 front drums
I picked up a pair of original used front F1 drums. One looks like it has 0.010 of wear and one looks like 0.020 of wear. Assuming I can get them to clean up at 0.030 or 0.040 over and the wear limit is 0.060 over, would I have any reduction in braking due to larger drum size?
JB
3twinridges is offline   Reply With Quote
Old 08-12-2020, 03:28 PM   #2
JSeery
JSeery's Avatar
Default Re: F1 front drums
The drums are designed to met specifications to .060 oversize.
Old 08-12-2020, 03:53 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
JB
Most likely only if you changed the size of the brake shoes which provide the sq.in. of braking area.
Old 08-12-2020, 04:27 PM   #4
alanwoodieman
what are you putting them on?
alanwoodieman is offline   Reply With Quote
Old 08-12-2020, 04:39 PM   #5
3twinridges
A 52’ F1 stock restoration. I have new reproduction drums on it now but would like the originals if they will work just as good.
JB
Old 08-12-2020, 04:51 PM   #6
CA Victoria
CA Victoria's Avatar
They will interchange. Turned drums and shoes are matched by arcing the shoe to match the drum. You will need to address this to ensure efficient braking.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 08-12-2020, 04:58 PM   #7
JSeery
JSeery's Avatar
Brake arcing is really important with Lockheed style brakes, but with Bendix brakes like the F1 it is not that big a deal and not normally done.
Old 08-17-2020, 09:45 PM   #8
3twinridges
Thanks bud. It’s good to know it’s not needed, as I can’t find anybody around Atlanta that can do it anyway!
JB
Thread Tools
Display Modes
