Old 08-06-2020, 08:28 AM   #1
Admiral
Admiral's Avatar
Default It’s a thing of beauty! But now some questions…
After a month in the clutches of the USPS, my reground Isky 1007B camshaft FINALLY arrived from D&L Automachine (Thanks, Pete1!). Ain’t it pretty? Seriously, it’s almost too nice to use…
Anyway, as I start sourcing parts for the engine in my 1951 Ford, I have a few questions.
1. What valve springs should I run with this cam? I’d like the lowest seat pressure I can get away with. Would stock springs work?
2. What brand of valves and/or what vendor do you recommend for purchasing valves?
3. I’ve got a nice set of EAB heads. Can I run them with a 4-inch Mercury crank? If not, I also have a smattering of 8BAs. I assume shoot for around 0.050" piston-to-head and valve-to-head clearance, right?
4. For simplicity and drivability, I plan on running a single carburetor. Do the four-bolt Mercury intake manifolds flow more than the three-bolt Ford units or are they pretty much the same? Not sure if finding a Merc unit would be an improvement.
Admiral is offline   Reply With Quote
Old 08-06-2020, 08:41 AM   #2
mfirth
Default Re: It’s a thing of beauty! But now some questions…
Admiral, Charlie NY did a 1 1/16 throttle bore 94 style carb for my 8BA with max 1 in it.
You could feel the difference, over the stcok 1" diameter 94. Just say'n. Charlie is easy to talk with..... Good luck & have fun!
mike
mfirth is offline   Reply With Quote
Old 08-06-2020, 08:50 AM   #3
Admiral
Admiral's Avatar
mike
Thanks for the feedback, mfirth! Actually, I've got a 1 1/16"-bore Holley rebuilt and ready to run. Glad to hear they work well with this sort of combination. I'm shooting for good drivability, lots of low- and mid-range torque, with a little more oopmh than stock. Also, you're totally right about Charlie. He's SUPER nice, helped me order some parts to rebuild that carb, actually.
Old 08-06-2020, 08:56 AM   #4
flatford8
flatford8's Avatar
I’d talk to Pete on your valve questions...Im going to use a Merc intake on my next engine. Like the idea of the bigger bore 94..... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 08-06-2020, 10:29 AM   #5
tubman
tubman's Avatar
I'm a little confused. The purpose of using a Merc manifold is to allow you to use a larger 4 bolt base carburetor (usually a Rochester 2G). Why would you consider a "bigger bore 94" (which flows a lot less than a 2G) which would require an adapter, which is usually not a good idea?
I will admit that I am a great booster of a 2G on a bored out merc manifold. The one problem I am having is getting the throttle to open all the way. Even with the throttle only opening 3/4 way, the increase in performance is impressive.
Old 08-06-2020, 11:16 AM   #6
40cpe
40cpe's Avatar
About your valve question, This is one man's opinion: I used the Hi flow undercut stainless chevy valves from Red's Headers because of the smaller base of the reground cam. To keep seat pressure fairly low, I used Red's Lincoln springs and one .060" shim to get around 50# on the seat.
I'm also using a 2G on a bored Mercury manifold and a Charlie NY chevy distributor. Overall, it is a. good, reliable system. I just wish I had used one of Pete's 1007B cams.
40cpe is offline   Reply With Quote
Old 08-06-2020, 11:23 AM   #7
flatford8
flatford8's Avatar
I liked the idea.... but obviously I would need to do more research. The way I read his post the big bore 94 was a Merc carb and was four bolt. When I’m ready to do the swap, maybe I can pick your brain on 2G info...... Mark
Billy Joe Shaver
Old 08-06-2020, 12:13 PM   #8
tubman
tubman's Avatar
If you're referring to me, please do, as I have done several. I have a jig that you can use to bore the manifold and had a bunch of 1/8" aluminum plates made to seal off the bottom of the 2G, which has some odd heat passages cast into it.
Old 08-06-2020, 04:49 PM   #9
flatford8
flatford8's Avatar
Yes, thanks. I had never heard of a “big bore-94” so I assumed it was a Merc carb. We all know what happens when we do that ...... Mark
Billy Joe Shaver
Old 08-07-2020, 05:21 PM   #10
Admiral
Admiral's Avatar
I was actually thinking of going with the valves offered by Red's Headers. I like that they have the non-grooved exhaust guides for slightly better heat transfer.
I think I'd like to run valve rotators for perhaps slightly improved longevity. Any idea if these work with the undercut, 1.5-inch Chevy valves?
Other than the four-bolt carburetor mount, is the Mercury manifold any different than the Ford design? Do they flow more?
Old 08-07-2020, 05:40 PM   #11
40cpe
40cpe's Avatar
In stock form I remember that the rotator valve keepers utilized a shorter spring than the non-rotators, but i don't remember how much shorter. I might be enough that you don't need shims. Or maybe too much if you don't use short springs. Maybe someone will chime in with the difference in length.
I can't help you with the flow differences.
Old 08-07-2020, 05:45 PM   #12
tubman
tubman's Avatar
I bore mine all the way down to the base of the manifold and then round the edges of the transition from the throttle bores. I have no real measurements, but it seems to me that when the vertical passages transition to the eight passages to the individual ports, a lot of passage volume is encountered.
Take a look down an intake manifold and see what you think.
