Old 07-07-2020, 09:00 PM   #1
IndianapolisRacer
Default 1941 Ford pickup seat
Got my Ford lowered in the rear 2 inches and works great , new problem after driving about 30 minutes that stock seat gets mighty uncomfortable , any solutions would be appreciated , still want stock appearance , thanks
IndianapolisRacer is offline   Reply With Quote
Old 07-07-2020, 09:55 PM   #2
51504bat
51504bat's Avatar
Default Re: 1941 Ford pickup seat
I finally bit the bullet and put a Glide Engineering seat in mt '39 p/u. Not cheap but much more comfortable. IMO
Old 07-07-2020, 09:57 PM   #3
cadillac512
cadillac512's Avatar
https://www.mccartys.com/product/standard/
I use one of these in my '41 Merc. Huge difference! Not cheap but absolutely fixes the seating /sore back problem.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 07-07-2020, 10:00 PM   #4
51504bat
51504bat's Avatar
Found a photo of the seat installed.
Old 07-08-2020, 07:31 AM   #5
TomT/Williamsburg
TomT/Williamsburg's Avatar
I have used the third seat out of a Chevy Suburban, 92-97, Dodge Caravan 3rd seats (or similar). I do not build stock restorations but they can be upholstered to look just like the stock seats ....
The pics are from my present 40 pickup I am building for my wife - seat is out of a 92-93 suburban .... sorry the second pic is sideways and I do not know why ...
File Type: jpeg BCBE39FB-080C-4EB9-BF47-67CCA4FC9B46.jpeg (101.6 KB, 56 views)
File Type: jpeg 2F0DFDAE-4EB6-44C9-A51E-9E30D977ED5B.jpeg (104.5 KB, 55 views)
TomT/Williamsburg is offline   Reply With Quote
Old 07-08-2020, 09:17 AM   #6
TJ
TJ's Avatar
I used the third seat out of a Windstar van and mounted it similiar to what Tom T did on his pickup. Those seats can be had at a local Pick-N-Pull for about $50 and many times have excellent upholstery on them. I did not use the seat tracks which allowed it to sit lower and I did not need the back and forth adjustment
Old 07-08-2020, 10:24 AM   #7
IndianapolisRacer
I think that is what I might do , can you get them already covered like yours ?
Old 07-08-2020, 10:45 AM   #8
Kube
Kube's Avatar
Before spending more $$$, remove the seat cushion and stuff each and every coil with carpet padding foam. Cut a piece of foam to the proper length (of the respective coil). Usually about an 18" run, roll it up and push it in. You will be amazed at the difference.
Old 07-08-2020, 10:50 AM   #9
38bill
38bill's Avatar
Originally Posted by Kube View Post
Before spending more $$$, remove the seat cushion and stuff each and every coil with carpet padding foam. Cut a piece of foam to the proper length (of the respective coil. Usually about an 18" run, roll it up and push it in. You will be amazed at the difference.
I basically did this to my stock seat. I also added a little extra foam in the lower back for some lumbar support and that made a huge difference.
38bill is offline   Reply With Quote
Old 07-08-2020, 07:04 PM   #10
35fordtn
35fordtn's Avatar
This sounds like a excellent idea Mike, I am too much a purist to install a van seat but my 36 pickup is very uncomfortable.. .
Old 07-08-2020, 09:38 PM   #11
TomT/Williamsburg
I like your solution, Mike!
Old 07-09-2020, 11:44 AM   #12
IndianapolisRacer
I am going to give that a shot , what do I have to loose , thanks .
Old 07-09-2020, 01:04 PM   #13
Kube
Kube's Avatar
Unless I have mint springs (rare these days) I do this within all of my restorations. Easy to accomplish, reasonable and no one will ever know.
Old 07-09-2020, 01:09 PM   #14
Mart
Mart's Avatar
We will.
Old 07-09-2020, 02:07 PM   #15
Kube
Kube's Avatar
Originally Posted by Mart View Post
We will.
Got me...
Old 07-10-2020, 07:13 AM   #16
Dak Rat
I used the carpet pad roll system in the seat of my '39 coupe years ago, yes it will cure a "saggy" seat!
Dak Rat is offline   Reply With Quote
