Old 07-04-2020, 02:47 PM   #1
Detonator
Detonator's Avatar
Default "Heavy" frame? Please educate me
I'm running a WANTED ad right now for a frame to put under my '35 coupe. Mine is so butchered I want to start fresh. I got a response from a Barner that has a "heavy" frame -- .010 thicker thru the outside rails -- built by Ford to go under woodies, open cars and trucks.
I've never heard of these.
I built a '38 woodie back in the 90's and my foggy memory recalled something about the cross tie pieces between the outside rails and the X that was different. But I don't recall hearing anything about a "heavy" frame before
Thanks.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 07-04-2020, 04:28 PM   #2
Floyd
Default Re: "Heavy" frame? Please educate me
The frames for "commercial cars" include 1/2 ton pickups, sedan deliveries, panels and probably station wagons are thicker. These frames were 0.010 " thicker than the passenger car frames. Thickness was 0.110" I believe. Of course the riveted on body mount brackets are different for each model.
You are looking for a pickup frame and then use your mounting brackets.
Floyd is offline   Reply With Quote
Old 07-04-2020, 04:28 PM   #3
VeryTangled
VeryTangled's Avatar
Hi Everyone. Detonator, I'll be interested in what your question reveals.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 07-04-2020, 04:46 PM   #4
woodiewagon46
I don't know about 1938 Ford Woodie frames, but the 1946 Ford Station Wagon was fitted to a regular passenger car chassis. There are production line pictures showing Station Wagons, Coupes and Sedans on the same line.
woodiewagon46 is offline   Reply With Quote
Old 07-04-2020, 05:11 PM   #5
DavidG
DavidG's Avatar
I seem to recall that the practice began with the '37 model year. My cabriolet has one of them under it.
Just because the frame is somewhat thicker would not mean that it required its own unique assembly line.
DavidG is online now   Reply With Quote
Old 07-04-2020, 07:31 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
We did a lengthy and very informative thread on this very subject last April. Click the link below. Pay PARTICULAR attention to everything that member Kube says throughout the thread! DD
https://www.fordbarn.com/forum/showt...t=heavy+frames
Click Links Below __
T5 W/TORQUE TUBE
Old 07-05-2020, 01:17 AM   #7
Tinker
Tinker's Avatar
This place is so great!
Old 07-05-2020, 03:32 PM   #8
Don Rogers
Don Rogers's Avatar
Detonator...Ford only used 3* frames from 1935 thru 1936.
48-5005 1935 and 36 passenger cars (Inc. station wagons and sedan deliveries) Job 1 thru end of production
50-5005 1935 and 36 commercial cars(pickup and panel deliveries) Job 1 thru end of production.
68-5005 (Light frame) 1936 passenger cars from approx April 1936 thru end of production Used concurrently with 48-5005 frame.
*NOTE: For a brief time (4/20/36 thru 5/13/36) Ford may have used the lighter frame in commercial production but went back to the 50-5005 frame for the remainder of 36 production..
Don Rogers is offline   Reply With Quote
Old 07-07-2020, 04:02 PM   #9
Don Rogers
Don Rogers's Avatar
Detonator, Here is an easy way to tell the lighter frame (68-5005) from the heavier frames.(48-5005, 50-5005) The bottom of the "X" member is different. Also the 50 frame is identical to the 48 frame except the side brackets/pockets are removed(48-5076,48-5077,48-5078 and 48-5079)
Old 07-07-2020, 04:25 PM   #10
Kube
Kube's Avatar
Interesting Don, as always.
I have never seen that "X" with the large circle out of it.
The frame to the right with the dimple? That was used on all Ford passenger cars in '39. I can't speak to earlier models. In 1940, that dimple was no longer there and instead, that area was fairly flat, having a small diameter (about an inch) hole in the center.
Kube is online now   Reply With Quote
Old 07-07-2020, 05:05 PM   #11
DavidG
DavidG's Avatar
Thanks, Don. As Mike notes, interesting, as always.
Old 07-07-2020, 06:23 PM   #12
rotorwrench
rotorwrench's Avatar
I wonder if Ford used any travel documentation that let the assembly line crews know what to build up for as each of these frames came down the line? Once a fair amount of obviously different parts were assembled then the travel documentation would not be as necessary. Just something to keep things from getting mixed up on the assembly line.
