Old 06-06-2018, 10:46 AM   #1
Admiral
Admiral's Avatar
Default Stromberg eFire Dizzy
Has anyone tried the new eFire distributor? It looks like another top-quality part from Stromberg, though at nearly $400 I question whether it's worth the upgrade over a stock crab unit with mechanical innards. You can buy A LOT of points and condensers for that much scratch!
http://www.stromberg-97.com/carburetion/efire.asp
Admiral is offline   Reply With Quote
Old 06-06-2018, 06:15 PM   #2
Kahuna
Kahuna's Avatar
Default Re: Stromberg eFire Dizzy
Admiral
I'm sure that is an excellent unit, but why not just convert your crab using a Pertronix trigger. Save a few hundred bucks
Jim
Kahuna is offline   Reply With Quote
Old 06-06-2018, 07:59 PM   #3
Lawrie
Lawrie's Avatar
And the crab has the vac brake
Lawrie
Lawrie is offline   Reply With Quote
Old 06-06-2018, 08:20 PM   #4
Ross F-1
Ross F-1's Avatar
Very little info on the unit; what kind of trigger? electronic pre-programmed advance, no advance??
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-07-2018, 09:45 AM   #5
Admiral
Admiral's Avatar
Originally Posted by Kahuna View Post
Admiral
Jim
Kahuna, currently I have no plans on replacing my car's tried-and-true crab-style distributor. I was just curious if anyone here on the Barn had tried this new unit and what its benefits might be. Looks like another great piece of engineering from Stromberg.
Old 06-07-2018, 02:10 PM   #6
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Mechanical advance 22 degrees just like the factory crab, uses a electronic module in lieu of contacts. Looks good , i ran a few when they were in development, success will depend on coil being used by end user.
Quality looks very good.....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 06-07-2018, 04:32 PM   #7
Jembow
Jembow's Avatar
I have done about 1000miles on mine and I can pull toward 4000rpm, which I couldn't manage on the divers helmet I have here. I'd like to find a stock crab for comparison.
Jembow is offline   Reply With Quote
Old 06-08-2018, 07:08 AM   #8
corvette8n
corvette8n's Avatar
I didn't see any coil options on the website, what coil is used for 6 volt?
Old 06-08-2018, 08:34 PM   #9
ford nut
ford nut's Avatar
I wanted one 4 or 5 months back, but couldn't get solid answers. I bought a stock crab.
ford nut is offline   Reply With Quote
Old 06-09-2018, 01:24 AM   #10
Jembow
Jembow's Avatar
Instructions say coil with a resistor in circuit but it wouldn't fire so Clive at Stromberg said try removing it. So I'm running a regular Bosch blue 6v coil. You also need modern plug leads, no copper cores.
Old 08-26-2018, 08:47 AM   #11
cajunfirehawk
cajunfirehawk's Avatar
Any updates, looking into one of these...
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 08-26-2018, 07:26 PM   #12
Talkwrench
Talkwrench's Avatar
"You can buy A LOT of points and condensers for that much scratch! " The issue now is are they any good..??
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 08-26-2018, 07:36 PM   #13
Yoyodyne
Yoyodyne's Avatar
What advance curve do they have? The page says "The advance rate (and max total advance) is tuned specifically to suit the flathead V8 motor".
Yoyodyne is offline   Reply With Quote
Old 08-26-2018, 10:51 PM   #14
flatheadmurre
flatheadmurre's Avatar
I´m curious why someone would take the time and money and develope a product that is less advanced then the original...
If they did a new crab distributor with a modern vacuum advance system that would be one thing.
I wouldn´t spend the money when rebuilding the original crab takes less money and you end up with a better distributor.
Old 08-27-2018, 02:36 AM   #15
OHV DeLuxe
I agree, i rebuild, test and run the 1942-48 "crab" distributor, for people and myself.
It`s hard to see any gains in this new unit, why replace the best distributor ever made for a modern unit which is hard to trace errors in, pluss it is missing the vacuum load brake.
OHV DeLuxe is offline   Reply With Quote
Old 11-12-2019, 09:18 AM   #16
Cheaterpete
Just installed one on a 3.9l, with isky max 1, was running great for 10 min and died...
Stromberg still not respond to me. I use a 1.5 ohm pertronix coil, with carbon spark plug wires. wired from the coil with good 12volts... don t understand what went wrong...
Any help will be appreciated
thanks
Cheaterpete is offline   Reply With Quote
Old 11-12-2019, 11:02 PM   #17
JSeery
JSeery's Avatar
thanks
No ballast resistor? I would guess you need 3.0 ohm in that circuit, 1.5 ohm is normally for a 6v system. You can get 3.0 ohm coils or use a 1.5 ohm coil with a 1.5 ohm ballast resistor.
