Old 05-13-2010, 02:00 PM   #1
kevinanderson
Default Underhood clean up
Anyone have a suggestion for cleaning the underside of my '35 hood. I thought about using Dawn dish soap and some fine steel wool.
kevinanderson is offline   Reply With Quote
Old 05-13-2010, 02:11 PM   #2
nelsb01
nelsb01's Avatar
Default Re: Underhood clean up
Before using steel wool, I would try a 3M scrubby --- it will be a lot easier on the paint.
Also, try spraying it with WD-40 ---- it might just loosen some of it up.
nelsb01 is offline   Reply With Quote
Old 05-13-2010, 02:15 PM   #3
skip
Banned
WD-40 or spray on minerial spirits.
Like solvent dissolve like substances.
Wipe a way.
Don't scourer away the paint and dull it.
p.s. Never touch your windshield with a 3-M Scotch pad unless you want ti scratched.
skip.
skip is offline   Reply With Quote
Old 05-13-2010, 02:41 PM   #4
Vic Piano
Vic Piano's Avatar
Try some Simple Green, spray it on, let it set for a few minutes and hose it off. Be sure to cove the Flathead with a plastic tarp to keep crud and water off of it.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 05-13-2010, 03:52 PM   #5
Ford46
Ford46's Avatar
I would try WD-40, Simple Green or like cleaner. I'd be leary of steel wool or an abrasive 3M pad unless you want to rebuff the paint under there (cleaning is bad enough). I try to keep underside of the hood clean, wiped and use some polish to make the next time easier. LouB.
Ford46 is offline   Reply With Quote
Old 05-13-2010, 05:04 PM   #6
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
Ditto on the 3M pads, they will even scratch chrome as well as glass. They really have no place in an auto cleaning kit unless all you have is a brushed finish in the first place.
Ross Murphy
1939 Ford Standard Coupe
Ross in East Texas is offline   Reply With Quote
Old 05-13-2010, 05:21 PM   #7
Frank The Plumber
If you want to preserve the paint you could try Fantastic orange cleaner to cut the grease, I use a #0000 polishing pad, 4 aught polishing pad, this is a synthetic, usually white in color pad for putting a polish or a buff on woodwork, I use it with tong oil finish and buff the coats between applications, this is not aggressive like a scotch brite but still has the porosity to absorb the gunk as you clean.
Frank The Plumber is offline   Reply With Quote
Old 05-13-2010, 05:36 PM   #8
01aford
01aford's Avatar
How dirty is it?
Caked on grease or just dusty dirt?
01aford is offline   Reply With Quote
Old 05-15-2010, 07:23 PM   #9
kevinanderson
75 years worth of grunge. was leary of the steel wool. hood is off and standing on end. don't want to stain the exterior of hood. 39k mile car.
Old 05-15-2010, 09:16 PM   #10
Tim Brown
Tim Brown's Avatar
Home Depot sells a product call Krud Kutter. It works very good on old grease and rinses off with water. I buy 2 bottles at a time...
Tim Brown is offline   Reply With Quote
Old 05-16-2010, 02:18 AM   #11
406Rich
406Rich's Avatar
I`ve used pinesol with good results, mixed 50/50 let sit for a couple of hours most stuff rinses off.
406Rich is offline   Reply With Quote
Old 05-17-2010, 01:14 PM   #12
joe plumber
Ditto on the Pinesol.On real grungy parts I have used easy off oven cleaner .
joe plumber is offline   Reply With Quote
Old 05-17-2010, 06:54 PM   #13
charles in east texas
charles in east texas's Avatar
I have said this many times on the old barn. I use "Awesome". Get it at the Dollar General store for a $1.00 a bottle. I have found nothing better. Spray on hose off, spray on hose off until all the grease is gone. Just be sure to hose with water until all soap is gone. If you don't like it, send me your address and I'll send you a $1.00.
Regards, Charles
charles in east texas is offline   Reply With Quote
Old 05-17-2010, 08:28 PM   #14
Ross in East Texas
Regards, Charles
Now, you just can't beat that guarantee! Thanks Charles.
Ross Murphy
Old 05-20-2010, 11:10 AM   #15
55 dude
55 dude's Avatar
i have said this many times on the old barn. I use "awesome". Get it at the dollar general store for a $1.00 a bottle. I have found nothing better. Spray on hose off, spray on hose off until all the grease is gone. Just be sure to hose with water until all soap is gone. If you don't like it, send me your address and i'll send you a $1.00.
Regards, charles
x2!
55 dude is offline   Reply With Quote
Old 05-23-2010, 06:45 PM   #16
Comet
Comet's Avatar
Super Clean has worked well for me also. Let it soak.
Comet is offline   Reply With Quote
