Old 03-22-2016, 05:45 PM   #221
flatjack9
flatjack9's Avatar
Default Re: 59 AB engine rebuild
Originally Posted by Macdozer View Post
Yes flathead murre that is what I am looking for.
Or if anyone has an idea of how I can make my own.
Send me a PM with your address and send you one for mailing cost.Jack
Old 03-23-2016, 06:07 AM   #222
Bored&Stroked
Bored&Stroked's Avatar
Originally Posted by flatheadmurre View Post
I think this is what he needs.
Like JSeery, I'm at a loss about this specific fitting . . . where does it plumb into and what is so special about it? (Other than looks).
It doesn't look like any fitting that I've ever used and it surely isn't pipe thread (somebody mentioned 7/16 NF). It almost looks like it has a diaphragm or one-way valve in it.
Where does it go and wouldn't one need a t-fitting to split from it to the distributor and vacuum wipers?
Enlighten me boys!
B&S
Old 03-23-2016, 06:53 AM   #223
Mart
Mart's Avatar
The fitting is a combined banjo bolt and vac takeoff for the wipers. the banjo bolt holds the vac advance pipe to the manifold and the wipers can be plugged onto the vac tube on the head of the fitting. There does appear to be some sort of diaphragm or valve but I have not dismantled one to look inside. The threas is a unf thread, I don't have one here to check the size but it could very well be 7/16 UNF.
Mart.
Old 03-24-2016, 08:16 AM   #224
Bored&Stroked
Mart.
So they used an actual banjo fitting for the distributor . . . and a regular rubber hose (needs to be flexible) to the wipers. Very interesting to say the least! If you happen to know, what years did they use them and on what cars/engines?
Old 03-24-2016, 08:57 AM   #225
JSeery
JSeery's Avatar
The only reason I could see for using something that obscure would be if you were attempting to be 100% authentic. A normal vacuum fitting would functionally accomplish the same thing.
