Old 04-28-2014, 12:49 PM   #1
ceejay
Default 33 Phaeton V8 and 4 cyl. rear radius rods same ?
HI all,
My 33 Phaeton is a 4 cylinder car.
I am installing 35 flathead V8 with its matching gearbox + 33 4cylinder rear axle + 33 V8 torque tube and drive shaft.
My question is, can I use my 33 4cylinder rear radius rods ?
ceejay is offline   Reply With Quote
Old 04-28-2014, 01:46 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 33 Phaeton V8 and 4 cyl. rear radius rods same ?
I would say so ,Ford would have just moved the mounting point rather than re tooling for a 4
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 04-28-2014, 02:33 PM   #3
DavidG
DavidG's Avatar
Yes, they are same including their part numbers. As stated earlier, the only two parts of the entire '33-'34 rear axle assemblies (four and V-8) that are different from one another are the torque tubes and drive shafts.
